Results 1 to 10 of 113
Thread: PEI Sheet for Bed Adhesion
02-05-2015, 05:38 PM #1
- Dec 2014
- Canada
- 498
I purchased a 1/16" 12x12 sheet of PEI Plastic
doing a first test directly onto it.. with nothing else
so far with ABS its sticking.. i really hope this is the adhesion holy grail lol
I know someone is going to ask so I got it here
http://www.mcmaster.com/#8685k43/=vs6z09Last edited by adamfilip; 02-05-2015 at 05:58 PM.
02-05-2015, 06:24 PM #2
- Nov 2014
- 522
there is something richrap made a blog post about i think called bed eez and it even allows nylon to stick, supposedly it's pretty awesome as well... i might try getting some
02-05-2015, 10:30 PM #3
- Nov 2014
- 58
PEI Sheet is great for adhesion. but kind of tricky also a least for a noobie like me . i have notice that you need to be a little high on first layer comparing to glass (hairspray method) also set the temperature 80 - 90 for ABS . if you go higher than that i will stick so much that you literally need to break the printed part to take it off .
at the beginning i was having issues trying to get it to stick , that was solved by sanding very lightly with a 5000 grit automotive sand paper . this is common with PEI Sheets with a glossy finish .
also do NOT use acetone on your sheet . i clean it with Alcohol , acetone will disolved abs into the "pores" of the sheet making removing parts very very difficult!.
now im thinking of buying another sheet .my doesnt seem to be perfectly flat even though is sticked to a glass with 3m 468mp transfer tapeLast edited by pichuete; 02-05-2015 at 10:36 PM.
02-05-2015, 10:37 PM #4
- Dec 2014
- Canada
- 498
I did a first print perfectly. snapped off easily once cooled.. havent sanded it.. still a high gloss finish, i also dont have it taped down. its just sitting ontop of my glass , held down by the binder clips
02-06-2015, 08:46 AM #5
- 6
Would this be the same thing?
http://www.amazon.com/dp/B0013HQ7B0/ref=biss_dp_t_asn
I only ask as I got a few amazon gift cards for Christmas and I can spend that without the spousal grief of ordering from McMaster. I cant just buy one thing from there.
Also how hard is it to cut this stuff? I have a 10" i3v so I would need to cut it down.
02-06-2015, 10:23 AM #6
- Feb 2015
- 70
adamfilip,
Did you use any cooling or heating of the piece or bed? Also, what hot end temp did you use?
Have you done any more experimenting with it?
02-06-2015, 10:41 AM #7
- Nov 2014
- 58
02-06-2015, 11:09 AM #8
- Dec 2014
- Canada
- 498
Ive printed 3 items on it..
so far its been really awesome..! im not exagerating
I printed some single wall items with no bottom layer that hold down well..
Printing ABS at 245, bed is 120
it holds strong until it cools to 30-35 degrees.. even at 50 degrees its still got a good hold
not using any cooling
Loving it so far.. havent tried it with PLA yet
02-06-2015, 11:11 AM #9
- Dec 2014
- Canada
- 498
02-06-2015, 12:19 PM #10
- Dec 2014
- 33
