    Technician N5QM's Avatar
    Jan 2015
    Little Rock, AR
    Gaps at Layer Change Location
    All,
    I have printed some 20mm cubes and dimensionally they look great, however I am seeing small gaps at the location that a layer starts/stops.
    If I set the layer change to happen in random locations it is all over the place, if I use the default value of changing in the same location, it ends up being a corner that looks "off".
    I am using Slic3r for all of this and was thinking that it might be a setting dealing with retraction on layer change and have started experimenting with that. Does anybody have a suggestion on what else I might try?
    Robert
    Jan 2015
    Little Rock, AR
    Well, I set it to no retraction on layer change and that didn't resolve the issue, the gaps still exist.
    I will measure the thickness of my filament again as I could see this being a case of not enough material being extruded maybe?
    Robert
    Were you able to solve the issue? I currently am dealing with similar gaps like you've mentioned while printing Benchy.
    Super Moderator
    Jun 2016
    Oklahoma
    See if coast or wipe is on and change it and see.
