Results 1 to 10 of 36
Thread: Better slicer?
01-30-2015, 11:51 AM #14
I'm going to have to respectfully disagree with that. It's possible that you have the 'Print Sparse Infill Every' setting set improperly. If it's at '1' then it prints the infill on every layer. If it's set on '2' it will print infill on every other layer and so on. You can really make a mess if you set it to '4' or something. What's nice is that you can also print a solid layer or diaphragm every 'x' layers. So if you wanted a stronger part and didn't want to use 100% solid infill, you could print a solid internal layer every 5 layers if you wanted to and in-between those would be the normal infill.
My parts are as strong as with any slicer I've used. It doesn't have a half-dozen infill algorithms available that others might, but for most parts under 8", I think it's way stronger than is necessary. You'd need NASA to run some tests to see which of the internal infill shapes are functionally stronger at a small scale. I'd bet the variation between them, even if extreme looking to a test bench score, are nominal in everyday practice. You can manually set the infill to print in any angle between 0 and 360 degrees and you set them individually. I can set the infill to 45 and -45 as well as 30, 15, 0, 90, 14, -12 (I think you see my point) and it will build lines of fill at all of those angles. At some point it gets absurd. But, I do not share the feeling that S3D creates weak parts that snap sideways. What allows parts to snap sideways is poor layer adhesion and improper settings can cause that with any slicer.Bambu P1S/AMS
