Results 41 to 43 of 43
Thread: Anyone recognize this motor?
01-20-2015, 11:19 AM #41
- Jun 2014
- Burnley, UK
- 1,662
M103 ;disable RPM M73 P0 ;enable build progress
G21 ;set units to mm G90 ;set positioning to absolute
(**** begin homing ****)
G162 X Y F2500 ;home XY axes maximum
G161 Z F1100 ;home Z axis minimum
G92 Z-5 ;set Z to -5
G1 Z0.0 ;move Z to "0"
G161 Z F100 ;home Z axis minimum
M132 X Y Z A B ;Recall stored home offsets for XYZAB axis
(**** end homing ****)
G1 X-141 Y-74 Z75 F3300.0 ;move to waiting position
G130 X20 Y20 Z20 A20 B20 ;Lower stepper Vrefs while heating
M6 T0 ;wait for toolhead, and HBP to reach temperature
M70 P5 (We Be Making Things!)
G130 X127 Y127 Z40 A127 B127 ;Set Stepper motor Vref to defaults
M108 R3.0 T0
G0 X-141 Y-74 ;Position Nozzle
G0 Z1 ;Move above plate
G1 Z0.3 ;Position Height M108 R5.0 ;Set Extruder Speed
M101 ;Start Extruder
G4 P3000 ;Create Anchor
G1 X-137 Y-70 Z0.1 F1000.0 ;Slow wipe
G0 Z0.3 ;and lift
This is the beginning of the Gcode that I have. I see the first option you mentioned but not the second. Where should I add it?
01-20-2015, 11:22 AM #42
- Jun 2014
- Burnley, UK
- 1,662
Yes, try 100.
You will not break anything it will just not move correctly or may skip steps if you go to low, if you are too high then it will still overheat.
01-20-2015, 11:23 AM #43
- Jul 2014
- 305
Thank you for the help!
I will try that today and see what I can do.
