Thread: Filament issue?
01-23-2024, 03:21 AM #1
- Jan 2024
Filament issue?
Hi,
I am new to 3d printing and am trying to print with a transparent PLA filament. I am using a FL Sun SR printer.
I want to print a single wall model with a large nozzle and quite hight layer height.
I have tried different things to fix the issue. I have changed the nozzle temp, speed, bed-leveling but nothing seems to fix this issue with filament looking strange mid print and not connecting the same way all through the print.
I use theese Cura-settings:
Nozzle: 1.0mm
Layer height: 0.64mm
Line width: 1.2mm
Wall thickness: 1.2 mm
Speed: 30mm/s
Bottom thickness: 2 layers, 1.28mm
Infill: 0
Print temp: 232 C
Retraction: 6.5 mm
What could be the issue here?Last edited by 123Theo; 01-23-2024 at 03:24 AM. Reason: Text
01-29-2024, 12:23 PM #2
- May 2020
- 620
If you are new to 3D printing perhaps try the standard 0.4mm nozzle initially.
I think that you are under extruding, jmo.
Basically you are trying to extrude a lot of molten plastic with a 1.00mm nozzle, can your hot end melt the required volume of filament quickly enough?
Ender 3 Neo - Jam Problem
