Results 1 to 6 of 6
    Newbie needs advice
    I've never owned a 3D printer before. Heck, I've never even USED one ... but I sure as heck WANT one. I've been watching YouTube videos, trying to learn as much as I can prior to purchase. Can anyone tell me anything about Simpify3D software?
    There's a couple of free programs I have, but it seems like it's taking an ENORMOUS amount of work to do even simple things. Let me tell you some of what I want to do:
    1: I want to be able to manipulate objects in 3D. That is, if I have a gear, connected to another gear, is there a program that will show me what happens if I rotate them?
    a. I have a gear. I have a long bar. I've joined the two together. I'd like to have another gear interface with the first, so I can push a lever that rotates the 1st gear, which then, in turn
    rotates the 2nd, which (because it's attached to the bar) rotates the bar.
    2: I want to take a 3D design (such as the U.S.S. Enterprise), and cut off certain parts - leaving me, say, with just the saucer. Then, I want to be able to create new parts to be "added" on top of the saucer (equal creations, left to right). I also want to be able to combine parts from OTHER 3D models.
    3: I'd like to be able to take a 3D model of a figure - say, a Warrior with a sword - and make slight modifications to it - delete a beard or add one; change the size or shape of the sword; change the armor (if I have other armor to meld in over the 1st set).
    4: I know Simplify3D will show me a preview of the print, slice by slice, and allow me to change the infill. Can it do any of the other things I've mentioned?
    I'm not sure I'm explaining myself well, but I sure could use some pointers.
    Technologist Roberts_Clif's Avatar
    Jun 2017
    Washington State, USA
    Fusion 360 - beware has a learning curve, though lots of videos on youtube.
    Free for Hobbyist and schools
    https://www.autodesk.com/products/fu...tudy-analysis/
    How to register
    https://knowledge.autodesk.com/suppo...usion-360.html
    Technologist
    Jul 2017
    Quote Originally Posted by TheQuestor View Post
    You have some misconceptions about Simplify 3D, what it is and what it does. It is a slicer that converts your 3D model into instructions for your printer, that's about it. It can move and arrange objects on your print bed for a job but that's as far as it goes. It does not make models.
    1) That is not the job of a slicer (what S3D is), it's the job of a constraint solver, a lot of 3D modeling programs have this. FreeCAD, fusion 360, solvespace and more. What exactly is taking a long time here? It's a fairly short and sweet task in any modeler that can do it.
    1) a) again, the job of a constraint solver. Nothing to do with a slicer.
    2)If you just want to combine pre existing models, meshmixer is probably the simplest software. If you want to make models like props or characters from movies and games, a parametric modeler like fusion 360 or freeCAD won't work as well since they're suited for engineering shapes, not organic ones. The issue here is that organic modelers that you'll want for these types of objects don't usually have constraint solvers (for your gears and such), I think blender does. Another thing is organic modelers aren't suited to making engineering parts like mechanisms and gears and stuff. You'd probably need to learn two programs for your two separate needs.
    3)Things are not nearly as simple as what you're describing ('delete the beard') unless someone made the beard as a separate part, and when using an organic modeler people rarely (never?) do this on purpose if at all. The beard is part of the head, and you'd need to remove it yourself, and then sculpt the details in to replace the beard. Think of it like a clay figure, you cant just 'delete' a beard on a clay figure, you need to cut it off then re sculpt what is underneath. Same goes for everything else you're asking about in #3.
    4)No, it can't.
    Your complaint seems to be that the software you have is taking 'a lot' of work to do 'simple' things. The thing is, you'll get better and faster at doing things with practice, and the things you're expecting to do are not simple. For #1 it's fairly simple in a powerful CAD program. For #2 cutting and combining models is relatively simple, but creating a part of the design yourself is not. For #3 these things just aren't simple, everything here requires you to sculpt the model yourself, at which point there isn't much point in using someone else's model.
    I created the bar in FreeCad. I used Maya 2014 to properly size the bar, and then move it into place, before merging the two objects. I then imported the object into a third program to make it a true .STL. What I really need is a program that I can use to do all of this. I like the look of the Autodesk - especially since they created Maya, which I'm already at least somewhat familiar with. My main problem with it is that you can't simply "buy" the software; you have to subscribe month by month, and that could get VERY expensive. I wouldn't mind spending $200-$300, but I only want to do it once.
    My problem with FreeCad was the lack of being able to freely move within the three-dimensional environment (i.e., panning around the object(s)). Do you know if Fusion360 will do most of what I'm looking for? Yes, I know I'd have to model stuff (on the figures); but IF I could do it (as if I were working with clay), I know I could accomplish what I want. I was able to do this with a character in Maya, so it should be available in other editors as well.
    Technologist
    Jul 2017
    FreeCAD can move within three dimensional space like you want, look up some tutorials. The scroll wheel click, left and right mouse buttons let you drag, pan and rotate to your heart's content. It's a sort of 'jack of all trades' with its 'workbenches' so it should be able to cover a very broad spectrum of CAD needs even outside of engineering parts.
    Also, why did you need to resize the bar in Maya? Why not just make it to the correct dimensions in FreeCAD and merge it with your other object in there? I think part of the trouble is coming from the fact you've got a long tool chain for something that can be done in one tool. Also, Maya and Fusion360 will be very different as they are completely different modeling softwares (organic vs engineering). As for the price, fusion is free for hobbyists, students and startups that earn under 100k per year. If you earn above 100k using the software, you need to pay like 200-300 per year, which is the most unreasonably cheap professional software I've ever seen. Since you wont be using it for a 100k+ business, you get it for free.
    Take a proper look at the software packages, I'd hate to say this but you obviously haven't done this. Simplify 3D is not a 3D modeler, and I haven't seen any posts or videos that imply it is. FreeCAD, just like every 3D modeling software, lets you move your view, pan around objects and dimension them properly. Finally, Fusion 360 is most likely to be free for your use case and worst case scenario will be very light on your six figure income.
    Ok, I now understand what Simplify3D is and isn't. That's helpful.
    It's a bit tough getting used to the 3D controls in FreeCAD, but I *WAS* able to do it. Thanks!
    My main problem with the various programs I have (Autodesk Meshmixer, Blender, DesignSpark Mechanical, FreeCAD, SolidWorks) was that I was having a real difficulty figuring out how to create a simple box to mesh with the existing gear. Once I figured it out, then the problem was modifying the box to be the unusual shape I wanted. I have the two melded together, but in DesignSpark & FreeCAD, you can see that they're two different "materials," and I can't figure out how to change that. Also, the bars have LOTS of polygons on them (visible in DS), which make them difficult (if not impossible) to manipulate in that program. That's why I went back to Maya - that was a program I knew how to use, at least.
    So, I've downloaded Fusion360, and I'm going to start taking a look at that. The Motion Study Analysis feature is one I will DEFINITELY need.
