Results 1 to 7 of 7
Thread: Z axis 1cm high skynet3d Anet a8
09-11-2017, 02:14 PM #1
- Sep 2017
- 35
Hi!
For some reason my Anet A8 has started printing 1cm too high. It happened after one print finished, when I tried to start the next one. I have adjusted the heatbed, lowered the nozzle, disabled the steppers and hand-moved the nozzle down to the bed. It is always 1cm:ish over the bed when is start a new print, no matter which print I do.
I am using Skynet firmware. No auto-level heatbed.
Cheers
09-11-2017, 02:39 PM #2
- Sep 2017
- 35
M140 S70.000000
M109 T0 S220.000000
T0
M190 S70.000000
;Sliced at: Sun 10-09-2017 20:09:51
;Basic settings: Layer height: 0.1 Walls: 1 Fill: 35
;Print time: #P_TIME#
;Filament used: #F_AMNT#m #F_WGHT#g
;Filament cost: #F_COST#
;M190 S70 ;Uncomment to add your own bed temperature line
;M109 S220 ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F9000 ;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F9000
;Put printing message on LCD screen
M117 Printing...
;Layer count: 211
;LAYER:0
M107
G0 F9000 X86.52 Y87.76 Z0.30
;TYPE:SKIRT
G1 F1200 X88.74 Y86.66 E0.15431
09-11-2017, 02:46 PM #3
- Sep 2017
- 35
Hmm, cant find anything similar to that. Made in Cura. Anything I can search for in the document?
09-11-2017, 02:47 PM #4
- Sep 2017
- 35
;Layer count: 211
;LAYER:0
M107
;TYPE:SKIRT
G1 X88.94 Y86.45 E0.17195
G1 X89.34 Y86.25 E0.19979
G1 X89.74 Y85.86 E0.23511
G1 X90.14 Y85.66 E0.26291
G1 X90.77 Y85.02 E0.31883
G1 X92.07 Y84.59 E0.40400
G1 X93.92 Y83.66 E0.53349
G1 X99.22 Y83.66 E0.86383
G1 X100.72 Y84.04 E0.96012
G1 X101.40 Y84.26 E1.00463
G1 X104.62 Y84.26 E1.20581
G1 X104.68 Y85.05 E1.25532
G1 X104.93 Y85.08 E1.27088
G1 X105.11 Y86.86 E1.38224
G1 X107.52 Y89.27 E1.59492
G1 X107.46 Y89.43 E1.60572
G1 X107.72 Y89.56 E1.62426
G1 X107.72 Y90.37 E1.67496
G1 X108.47 Y90.46 E1.72177
G1 X108.54 Y90.86 E1.74743
G1 X109.32 Y90.86 E1.79576
G1 X109.94 Y91.48 E1.85061
09-11-2017, 02:48 PM #5
- Sep 2017
- 35
Nah, this print worked before ^^
Slicer is at 0.06mm layer height
09-11-2017, 02:53 PM #6
- Sep 2017
- 35
Check PM
(Not my model, so sent file-link there)
09-12-2017, 01:45 AM #7
- Sep 2017
- 35
Found a temporary fix (could be permanent, it works well). Removing these lines, then hand-setting the nozzle to the right height before each print:
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
There is no sensor that could be broken, I assume? I dont have auto-level, or anything like that. Just a stock anet a8.
