Results 1 to 5 of 5
Thread: Print problem
    Print problem
    See attached picture. My Hictop printer has been printing great without issue, but recently started doing this. This is a 10x10x20mm test column. As you can see it is not smooth. Any ideas on what is causing this? I have y & x axis belts with no improvement.
    Engineer-in-Training ralphzoontjens's Avatar
    Nov 2013
    Tilburg, the Netherlands
    Follow ralphzoontjens On Twitter Add ralphzoontjens on Facebook Add ralphzoontjens on Shapeways Add ralphzoontjens on Thingiverse
    Can you post the picture again?
    I have tried. Does not seem to be working.
    Nov 2013
    Uploading a smaller picture usually works better.
    It is likely to do with your flow and temperature settings.
    But it can also be that a component of your print bed assembly or end stop mounts are loose.
