Results 1 to 7 of 7
03-21-2017, 07:11 PM #1
- Mar 2017
- 7
printer printing onto the air instead of the plate
I have a Monoprice MP Select Mini 3D Printer, and I recently got in my filament. I am trying to print a test job, but the printer is not printing onto the plate. it is instead printing into the air. If I make the printer nozzle go lower it resents to a higher position before I print. Please someone help me.
03-21-2017, 07:52 PM #2
Recalibrate or relevel the bed. The bed is most likely in a different position than where the printer thinks it is. If not, check your gcode for some instruction causing it to lift. What slicer are you using? There my be a setting wrong there.
03-21-2017, 08:05 PM #3
- Mar 2017
- 7
Im using slic3r. I may know what it is. is there A way I can post a video to the thread?
03-21-2017, 08:14 PM #4
- Mar 2017
- 7
Actually I believe I have it fixed but it may only be temperary. but I am having a new problem. I am printing but it isnt sticking to the board. only some of it sticks
03-22-2017, 09:19 AM #5
- Mar 2015
- Fenton, MI
- 63
I had slic3r raising my nozzle about 2 mm before every print. I switched to Matter Control. Better interface and consistent prints.
03-22-2017, 09:57 AM #6
- Mar 2017
- 7
What setting raises the nozzel in splicer? And i may try that as well
03-23-2017, 12:18 AM #7
