Results 1 to 8 of 8
11-22-2016, 05:44 AM #1
- Nov 2016
- 11
Auto bed leveling G29 data ignored during print
Hi
I decided to add auto bed leveling/trimming on my printer using a PNP inductive proximity sensor switch (LJ12A3-4-Z/BY).
At the moment I have managed to get the initial set up, were to probe, how far and replaced my normal z endstop switch.
To verify my set up, I decided to use this as a test print in order to verify bed level feature.
So far I have been unable to successfully make this work, get a levelled bed, part of the bed is ok but not the other part.
I have tried to use two different points in order to get the z probe offset, the bed centre and the start of the bed (0,0) which differ with 0.1mm.
Both yield the same result.
Here are G29 results run after each other with a -1mm z prob offset from the nozzle
SENDING:G29
Bed x: 0.00 y: 0.00 z: -0.96
Bed x: 155.00 y: 0.00 z: -0.83
Bed x: 155.00 y: 180.00 z: -0.60
Bed x: 0.00 y: 180.00 z: -0.89
Eqn coefficients: a: 0.00 b: 0.00 d: -1.00
planeNormal x: -0.00 y: -0.00 z: 1.00
echo:endstops hit: X:0.01 Y:179.99 Z:-0.89
SENDING:G29
Bed x: 0.00 y: 0.00 z: 1.00
Bed x: 155.00 y: 0.00 z: 1.16
Bed x: 155.00 y: 180.00 z: 1.38
Bed x: 0.00 y: 180.00 z: 1.09
Eqn coefficients: a: 0.00 b: 0.00 d: 0.97
echo:endstops hit: X:0.01 Y:179.96 Z:1.09
SENDING:G29
Bed x: 0.00 y: 0.00 z: 1.08
Bed x: 155.00 y: 0.00 z: 1.22
Bed x: 155.00 y: 180.00 z: 1.45
Bed x: 0.00 y: 180.00 z: 1.16
Eqn coefficients: a: 0.00 b: 0.00 d: 1.05
echo:endstops hit: Y:179.99 Z:1.16
Any ideas on how to solve this?
Seems like the data obtained by G29 isn't used at all even if I can clearly see the Z axis move while printing.
Thank you in advance
11-22-2016, 12:08 PM #2
Those numbers do not look correct. What version of the code do you have? It might make sense to being up RCBugFix which is the most current and fixed version of Marlin. You can get it here if you decide to do that: https://github.com/MarlinFirmware/Marlin/tree/RCBugFix
It would also be good to see a M48 V4 on your current setup so we can see how the Z-Probe is behaving.
11-22-2016, 12:56 PM #3
- Nov 2016
- 11
Hi,
I'm on Marlin version 1.0.2-2.
Code:Front-left point >>> m48 v4 SENDING:M48 V4 M48 Z-Probe Repeatability test. Version 2.00 Full support at: http://3dprintboard.com/forum.php Positioning probe for the test. 1 of 10 z: 0.906500 mean: 0.906500 sigma: 0.000000 2 of 10 z: 0.908125 mean: 0.907312 sigma: 0.000813 3 of 10 z: 0.909250 mean: 0.907958 sigma: 0.001129 4 of 10 z: 0.908875 mean: 0.908187 sigma: 0.001055 5 of 10 z: 0.909500 mean: 0.908450 sigma: 0.001080 6 of 10 z: 0.910125 mean: 0.908729 sigma: 0.001167 7 of 10 z: 0.911000 mean: 0.909054 sigma: 0.001341 8 of 10 z: 0.911875 mean: 0.909406 sigma: 0.001563 9 of 10 z: 0.912875 mean: 0.909792 sigma: 0.001833 10 of 10 z: 0.913250 mean: 0.910138 sigma: 0.002025 Mean: 0.910138 Standard Deviation: 0.002025 echo:endstops hit: Z:0.91 Front-right point >>> m48 v4 SENDING:M48 V4 M48 Z-Probe Repeatability test. Version 2.00 Full support at: http://3dprintboard.com/forum.php Positioning probe for the test. 1 of 10 z: 0.853875 mean: 0.853875 sigma: 0.000000 2 of 10 z: 0.857125 mean: 0.855500 sigma: 0.001625 3 of 10 z: 0.859375 mean: 0.856792 sigma: 0.002258 4 of 10 z: 0.860250 mean: 0.857656 sigma: 0.002463 5 of 10 z: 0.861750 mean: 0.858475 sigma: 0.002745 6 of 10 z: 0.862250 mean: 0.859104 sigma: 0.002874 7 of 10 z: 0.863500 mean: 0.859732 sigma: 0.003073 8 of 10 z: 0.864375 mean: 0.860313 sigma: 0.003259 9 of 10 z: 0.865500 mean: 0.860889 sigma: 0.003478 10 of 10 z: 0.866750 mean: 0.861475 sigma: 0.003739 Mean: 0.861475 Standard Deviation: 0.003739 echo:endstops hit: Z:0.87 Back-right point >>> m48 v4 SENDING:M48 V4 M48 Z-Probe Repeatability test. Version 2.00 Full support at: http://3dprintboard.com/forum.php Positioning probe for the test. 1 of 10 z: 0.156000 mean: 0.156000 sigma: 0.000000 2 of 10 z: 0.156875 mean: 0.156438 sigma: 0.000437 3 of 10 z: 0.158125 mean: 0.157000 sigma: 0.000872 4 of 10 z: 0.158500 mean: 0.157375 sigma: 0.000996 5 of 10 z: 0.159875 mean: 0.157875 sigma: 0.001339 6 of 10 z: 0.168000 mean: 0.159563 sigma: 0.003966 7 of 10 z: 0.160875 mean: 0.159750 sigma: 0.003701 8 of 10 z: 0.160750 mean: 0.159875 sigma: 0.003478 9 of 10 z: 0.160250 mean: 0.159917 sigma: 0.003281 10 of 10 z: 0.160625 mean: 0.159987 sigma: 0.003120 Mean: 0.159987 Standard Deviation: 0.003120 echo:endstops hit: Z:0.16 Back-left point >>> m48 v4 SENDING:M48 V4 M48 Z-Probe Repeatability test. Version 2.00 Full support at: http://3dprintboard.com/forum.php Positioning probe for the test. 1 of 10 z: -0.233375 mean: -0.233375 sigma: 0.000000 2 of 10 z: -0.232250 mean: -0.232813 sigma: 0.000562 3 of 10 z: -0.231875 mean: -0.232500 sigma: 0.000637 4 of 10 z: -0.232125 mean: -0.232406 sigma: 0.000575 5 of 10 z: -0.232125 mean: -0.232350 sigma: 0.000527 6 of 10 z: -0.232125 mean: -0.232313 sigma: 0.000488 7 of 10 z: -0.232250 mean: -0.232304 sigma: 0.000452 8 of 10 z: -0.232125 mean: -0.232281 sigma: 0.000427 9 of 10 z: -0.232125 mean: -0.232264 sigma: 0.000406 10 of 10 z: -0.232125 mean: -0.232250 sigma: 0.000387 Mean: -0.232250 Standard Deviation: 0.000387 echo:endstops hit: Z:-0.23 And G29 results SENDING:G29 Bed x: 1.00 y: 1.00 z: 0.94 Bed x: 155.00 y: 1.00 z: 0.87 Bed x: 155.00 y: 179.00 z: 1.11 Bed x: 1.00 y: 179.00 z: 0.75 Eqn coefficients: a: 0.00 b: 0.00 d: 0.83 planeNormal x: -0.00 y: -0.00 z: 1.00 echo:endstops hit: Z:0.75
11-22-2016, 04:46 PM #4
- Nov 2016
- 11
Update:
Tried the Marlin RCBugFix version and the same problem that I had before still prohibits me from lowering the nozzle so that I can calculate the z-probe offset.
Even if I change the Z min to -2 I couldn't lower the nozzle, so I'm basically back to square one.
I think I will get a new glass since the one I have ain't totaly flat, a few 0. mm apart from corner to corner and try that out and see if it helps.
Q: Does it matter if G90 is placed after or before G29 in the gcode?
11-22-2016, 05:33 PM #5
What are these values in your Configuration.h file?
#define min_software_endstops false //true // If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops false //true // If true, axis won't move to coordinates greater than the defined lengths below.
If you set them to false... It is very possible your Z probe comes alive.
11-22-2016, 05:50 PM #6
- Nov 2016
- 11
They are both set to true in both versions.
If I disable them (set them to false), won't that be totally removing any safety measures for travel over the a given axis length?
Does it matter if G90 is placed after or before G29 in the gcode?Last edited by Zuru1; 11-22-2016 at 06:15 PM.
11-23-2016, 04:43 PM #7
- Nov 2016
- 11
So I changed to the RCBugFix version and disabled min_software_endstops and was able to calculate z probe offset.
Same behavior as before when printing the calibration print no matter how close the nozzle is without being to close to the bed(without scratching the bed), no adjustments where made during printing as can be seen in the picture.
Attachment 9866Attachment 9867
I will try to get a new glass tomorrow and see how that goes before i revert back to not using ABL since I have been at it for while now and haven't come any were since I configured this feature.
Edit: Here is the output of G29 V4 and print out put on RCBugFix firmware
>>> G29 V4
SENDING:G29 V4
G29 Auto Bed Leveling
echo:busy: processing
Bed X: 155.000 Y: 0.000 Z: 0.409
Bed X: 0.000 Y: 0.000 Z: 0.962
Bed X: 0.000 Y: 185.000 Z: 0.900
Bed X: 155.000 Y: 185.000 Z: 0.769
Eqn coefficients: a: -0.00220726 b: 0.00080608 d: 0.85656232
Mean of sampled points: 0.76006250
Bed Height Topography:
+--- BACK --+
L | (+) | R
E | | I
F | (-) N (+) | G
T | | H
| (-) | T
O-- FRONT --+
(0,0)
+0.14019 +0.00894
+0.20194 -0.35106
Corrected Bed Height vs. Bed Topology:
+0.00000 +0.21088
+0.21088 +0.00000
Bed Level Correction Matrix:
+0.999998 +0.000000 -0.002207
+0.000002 +1.000000 +0.000806
+0.002207 -0.000806 +0.999997
Print started at: 23:10:22
Eqn coefficients: a: -0.00225887 b: 0.00070338 d: 0.84381237
+0.999997 +0.000000 -0.002259
+0.000002 +1.000000 +0.000703
+0.002259 -0.000703 +0.999997
Also my initial beginning of my gocde:
; generated by Slic3r 1.2.9 on 2016-11-21 at 20:37:21
; external perimeters extrusion width = 0.40mm
; perimeters extrusion width = 0.67mm
; infill extrusion width = 0.67mm
; solid infill extrusion width = 0.67mm
; top infill extrusion width = 0.67mm
; support material extrusion width = 0.40mm
M107
M190 S60 ; set bed temperature
M104 S215 ; set temperature
G28 ;Home all axises
M117 Homing all axises
G29 ;Level bed
M117 Auto bed leveling
G1 Z5 F5000 ;Lift nozzle
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F9000
M117 Printing...
M109 S215 ; wait for temperature to be reached
G21 ; set units to millimeters
G90 ; use absolute coordinates
M82 ; use absolute distances for extrusion
G92 E0
G1 E-1.00000 F2400.00000
G92 E0
G1 Z0.250 F7800.000Last edited by Zuru1; 11-23-2016 at 04:50 PM.
11-28-2016, 04:39 PM #8
- Nov 2016
- 11
Well I replaced the glass and got a flat bed and recalibrated the hole printer twice just to make sure and still no change.
I also tried RC7 firmware version to see if that would solve anything, still same end results.
So my only solution now is to go back to the original endstop since I already have invested a lot of time and still have nothing to show for it.
Yesterday, 03:08 PM in 3D Printer Parts, Filament & Materials
