    Issue when trying to print
    Hi,
    I am trying to print any file, but everything I do, it is as if the home axes were offset. I have tried to reset the settings to default but it doesn't seem like anything is getting fixed. Does anyone know how to fix this issue?
    It is a MakerBot Replication 2X
    oh right. check the endstop is:
    1) still where it should be.
    2) working.
    That's most likely the problem, the carriage is either not clicking the x-axis endstop or the endstop is not working.
    Student
    Mar 2016
    Düsseldorf
    Hi,
    I had the same problem.
    https://www.youtube.com/watch?v=SvZV-lnRtj0
    In my case the x-axis cable had a loose contact. It broke behind the metal pin.
    I was soldering the cable and now it works again, but you can als order a replacement cable.
    Cheers
    Thomas
    Technician
    Mar 2015
    Slovenia, Europe
    #fontseeker
    you have broken end-stop switch. Replace it and this problem will be fixed.
Tags for this Thread
