Results 11 to 14 of 14
Thread: Bed Temp not accurate
11-25-2016, 05:52 PM #11
- Aug 2016
- 13
I'm going to better document my build on my blog but probably not until after the first of the year. Unfortunately the numbers/code I used in the Marlin Config file isn't going to be applicable to other Pegasus 10 users since I flipped the gantry on mine so everything is on the left side and 0,0 is in the front left corner like my other printers .....
Trust me it will be worth the wait, it's built on a Harbor Freight work table with printed feet that can also accept locking wheels and includes a Raspberry Pi 3 with a 5" touchscreen that can be used as an octo-print rig or can be used like a computer to download and slice files and control the printer with Pronterface. It's a completely self contained stand alone unit that all you need is an outlet to plug it into and an available WiFi connection. I wanted something I could easily move from my workshop into my computer/design room. The entire reason I bought and designed this is because I blew my back out in late June and couldn't get out in my boat. So I built a new printer instead ...... I didn't even plan to start this until next year
Depressed? Life has got you Bummed Out? Build a new printer ......
11-25-2016, 06:00 PM #12
- Jul 2016
- Pennsylvania, USA
- 255
Hi
With a probe (any mechanical probe) you probably need the bed and carriage in a defined location as the warmup occurs. Where that is probably does not matter as much as it being the same every time. Most probes heat up more from the bed than from the extruder and that's why the bed to carriage relation matters.
Bob
11-26-2016, 02:34 PM #13
- Aug 2016
- 13
11-26-2016, 02:42 PM #14
- Jul 2016
- Pennsylvania, USA
- 255
Ender 3 Neo - Jam Problem
