09-13-2016, 05:15 PM #1
Thor3D Unveils Drake, the 3D White Light Scanning System
Moscow-based 3D imaging company Thor3D has just unveiled Drake, their wireless and handheld new 3D scanning system that’s capable of capturing both small and large objects. The Drake is a white light 3D scanner that comes equipped with three interchangeable sets of lenses, each with a different Field of View (FoV) to scan different sized objects, from an entire car to a gear-shift handle. Depending on which set of lenses are used, the maximum accuracy of your data will be between 40 and 200 microns, while the maximum resolution will rest somewhere between 0.15mm and 1.00mm. The Drake 3D scanning system can currently be pre-ordered by contacting Thor3D through their website. Read more at 3DPrint.com: https://3dprint.com/149146/thor3d-drake-scanner/
