Thread: x homing in wrong direction
06-08-2016, 02:15 AM #1
- Apr 2016
- 30
the issue was that my software was causeing the issue.
The issue I am having now is, when I start a print, the printer zeros all axis, and moves tot eh center of the bed. Moving to the center, it raises the Z axis to avoid collision. It does nto, however, rezero the Zaxis and attempts to start the print from the height that it moved to for safety.
makerfarm I3v 12"
marlin firmware from the Makerfarm Website
Rumba
Capacitive sensor(18mm one)
Thanks in advance guys! (And girls too, Roxy. I havent forgotten how awesome you are )Last edited by bzmotoninja83; 06-08-2016 at 03:52 AM.
06-18-2016, 01:31 AM #2
- Jan 2015
- 36
Sounds like you need to alter the offset between the hotend and the bed.. if you look in the marlin config file for "#define Z_PROBE_OFFSET_FROM_EXTRUDER"
You can also use gcode to set it "M206 Z5" would add 5mm to the offset (you can also use negative numbers) once set issue a M500 to store in EPROM you don't have to set it every time you turn the printer off
Today, 03:08 PM in 3D Printer Parts, Filament & Materials
