Results 1 to 10 of 16
04-29-2016, 01:23 PM #1
- Apr 2016
- 7
[Prusa i3] Too much extrusion, only on edges
Hello,
I'm having an issue while printing, hopefully you can see it on this video :
https://www.youtube.com/watch?v=MIov9xAa5Es
This happens on "complex prints", it prints pretty fine on simple objects (like a cube).
I don't think it is over extrusion, i spent quite a long time calibrating this, and it is only on SOME edges...
I'm out of ideas, can anyone help me ?
Thanks a lot !
04-29-2016, 09:52 PM #2
- Mar 2014
- 223
Which slicing software did you use?
04-30-2016, 01:59 AM #3
- Apr 2016
- 7
Hello,
I'm using slic3r, with Geeetech repeiter host.
04-30-2016, 04:14 AM #4
- Mar 2014
- 223
04-30-2016, 11:33 AM #5
- Apr 2016
- 7
Actually i was on an old version of slic3r when recording this video ( i think it was 1.1.7), i then upgraded to 1.2.9 and had the exact same issue...
04-30-2016, 02:28 PM #6
Looks to me like you're trying to add new layers on top of material that isn't firm enough.
Is this PLA filament? If so, adding print cooling airflow would help.
04-30-2016, 04:52 PM #7
- Apr 2016
- 7
Yes it is PLA.
What do you mean exactly by "print cooling airflow"? I already have the fan always on
04-30-2016, 06:04 PM #8
If you don't know what print cooling airflow is, you probably don't have any. This isn't the fan that is typically mounted on to the hot end to cool off a heatsink. Print cooling airflow usually involves a separate fan (or small blower) with a duct or shroud that provides a stream of ambient airflow onto the print right below the hot end nozzle.
PLA can be problematic in that it retains heat for quite a while, remaining fairly soft for a long time. The video isn't the greatest, but it seems to show the print shifting underneath the nozzle. This is a classic sign of trying to print fresh material onto layers that are still soft. Print quality almost always suffers when that is happening. On overhangs (like on your print), the overhang will tend to curl upwards. 90-degree corners tend to end up rounder than they should be.
PLA print thermal management can involve a number of factors. You don't want to print PLA on a bed any warmer than necessary. You don't want the nozzle temperature any higher than it has to be. You can set up a minimum layer time in the slicer which can help, at least to an extent. You can print multiple copies or multiple designs at a time. As I mentioned, adding or increasing the amount of airflow specific to cooling off the printed material will usually provide the most significant way to minimize issues with residual heat in the extruded PLA. This blower-based cooler is specific to my MakerFarm i3v printer, but it'll give you an idea what I'm talking about - http://www.thingiverse.com/thing:461014Last edited by printbus; 04-30-2016 at 06:56 PM. Reason: added printing multiple parts at a time
04-30-2016, 07:54 PM #9
- Feb 2015
- 70
awanegenebayo,
I have struggled with this EXACT problem for a year. What causes this, as far as I can tell, is very aggressive overhangs. It happens to me on every overhang where a significant portion of the flesh filament (PLA) is extruded over the air and it has very little to bond to. I tried everything, including cooling to no avail. I was finally able to overcome most (but not all) of the issue by significantly increasing my extrusion temperature. I was printing at 193 and had terrible overhangs just like yours. After a few experiments I found that 210 and even 215 work much better. I tried to go higher (220) but started experiencing jams.
What temps are you printing at? Please try bumping up your temp and let me know how it works for you!!
05-01-2016, 05:44 AM #10
- Apr 2016
- 7
Thanks a lot for your answers !
I'm having two opposite adivces here haha !
I'm currently printing at 180 for the extruder and 85 for the bed. I think the bed may be a little hotter than necessary, i'll try printing something at 75.
I will also try to significantly increase the extrusion temperature, just to see what's going on, but it seems completely at the opposite of what printbus what saying, that is layers don't have time to cool down before the next layer is made. I'll try anyway, PLA is cheap
If i can't get any improvements, i'll consider buying a fan and printing a cooling airflow piece.
Thanks again for the help !
PS : For the record, this is what most if my prints look like :
IMG_20160501_125421.jpgIMG_20160501_125433.jpgLast edited by awanegenebayo; 05-01-2016 at 05:53 AM.
Ender 3 Neo - Jam Problem
