Results 1 to 5 of 5
03-13-2016, 06:13 PM #1
- Mar 2016
- 4
Blown fuse for heated bed Prusa i3
Hi all, I have a Prusa i3 Printer I recently bought on eBay. Today was the first day I had it running and printing properly I had it printing probably about 6 hours solidly. I had a break for some food and came back and noticed the bed wouldn't heat up. After a bit of investigation I found a blown fuse on the board.
See photo, under the power connector fuse on the right.
It is marked LF15a.
I believe it is one of these 2
http://uk.rs-online.com/web/c/fuses-...sid=4294959274
Am I right in thinking the voltages specified are max and I will be fine with the 65v ones?
I also had other questions, any idea why it blew? I read somewhere these beds can run at 180c, I had mine set at 110c which translates to 60-65c on the glass surface. Was I pushing it too hard?
Thanks Chris
03-14-2016, 09:48 AM #2
I think that fuse opened up due to a bad fuse socket. You will need both.
03-14-2016, 11:14 AM #3
- Mar 2016
- 4
03-25-2016, 07:08 AM #4
Sorry for the delay,... Yes, you will need to de-solder and re-solder a new socket on the board.
08-28-2017, 02:42 AM #5
- Aug 2017
I have this exact issue (mine looks even more burnt out) did you manage to fix it yourself in the end?
Sourcing a new socket has been a real pain for me.
Do bed magnets deteriorate.
