02-17-2016, 12:54 AM #1
- Feb 2016
Shift of build when making two color item.
I have a problem when I do 2 color printing. When it starts printing with the second extruder I get a frame shift -- see pictures. If I print the same model with a single extruder, right or left, all works fine. However, if I merge two parts of the model with ReplicatorG I get the shift either to the right or left. Help please!
02-17-2016, 12:58 AM #2
- Sep 2014
- Brummen, Netherlands
- 265
If either of your nozzles alone works fine, then it is not a height issue. My guess is that you need to specify the correct distance between the two nozzles in your slicer. There should be a setting somewhere.
02-17-2016, 10:50 AM #3
could be several things.
1) you need to calibrate/align the nozzles for dual nozzle printing. Similiar to aligning inkjet nozzles the printer needs you to tell it if the nozzles aren't quite in alignment.
2) rep-g sucks - it's just the most awful 3d printing software ever written (that I've seen). Try with makerware. I'd say get simplify 3d - but that's still useless for dual extrusion prints. Great for everything else - but still crap for dual prints. Makerware works great for dual extrusion prints.
3) are you creating two seperate files from asingle model in your cad software, which should work - or relying on rep-g to stitch together two different, in which case see point '2' and most likely also point '1'
In fact if I had to bet I'd bet on it being an alignment issue
