Results 11 to 20 of 21
12-02-2015, 04:52 AM #11
- Nov 2015
- UK
- 13
Okay I've Disabled Max End stops in configuration h, which has now left me with only the min end stops when running a M119 Command. I can confirm that when i press the end stops, the state changes, however they are triggered and when pressed, open.
Because of this i have inverted the logic in configuration h, which now shows them triggered when pressed, which is what I required.
What would be my next step in getting towards my first print?
Thanks for your help so far, its been extremely helpful.
12-02-2015, 11:43 AM #12
Do a G28 and verify it homes properly. Turn on the heat bed and the nozzle and verify those heat up and hold steady in temperature. Then tell it extrude to 10mm or 20mm of filament and see what it does.
Go back to the start and home. Verify you can just slip a piece or two of paper under the nozzle. And if so.... press the 'Print' button!
12-03-2015, 04:56 AM #13
- Nov 2015
- UK
- 13
12-03-2015, 08:08 AM #14
You do know printing even a small, hollow 20mm^3 calibration cube can take 15 or 20 minutes, right? The plastic doesn't come out of the nozzle very fast. It might be time for you to take a video and show us the first layer of something being printed. We can tell a lot more from that.
12-03-2015, 10:33 AM #15
- Nov 2015
- UK
- 13
Yeh I inow it takes time, but what I mean is the printer is moving around and can see it moving up the z axis on the different layers but there isn't any extrusion because the gears are barely moving. However like I said the motor spins and extrudes fine manually through pronterface. I can certainly add a video you evidence this if required?
12-03-2015, 11:54 AM #16
When you tell it to extrude 10mm of filament in Pronterface, it extrudes that much of what is being feed into the extruder, right? That isn't how long of piece comes out, right?
A video would be helpful.
12-04-2015, 09:39 AM #17
My first initial guess is that your nozzle diameter/filament diameter is set incorrectly in your slicing software. This would lead to incorrect extrusion rates when trying to print a sliced part, but would not effect pronterface extrusion.
12-07-2015, 04:38 PM #18
- Nov 2015
- UK
- 13
Heres the video, sorry it took so long. As you can see its 4 minutes of the printer running then at the end you can see how much plastic has been extruded.
https://www.youtube.com/watch?v=_ICO-AYqHbw&feature=youtu.be
12-07-2015, 04:39 PM #19
- Nov 2015
- UK
- 13
12-07-2015, 04:47 PM #20
Do bed magnets deteriorate.
