    Student papabur's Avatar
    Nov 2013
    Portland, Oregon
    Follow papabur On Twitter Add papabur on Facebook Add papabur on Google+ Add papabur on Thingiverse
    papaburs RAMBo v1.2 guide
    I have been using the RAMPs v1.4 and Arduino Mega 2560 since I first got into 3d printing but I recently decided that there has to be something better out there..and I think I may have found it. After saving up 180$, I ordered a brand new RAMBo v1.2 board from ultimachine.com (Great company!). The kit includes: 3 mechanical endstops, 2 thermistor wire sets(i did not end up needing these), a 6-pin plug, Five 2-pin plugs, 1x4 housing/connectors(x6) and 1x2 housing/connectors(x1).
    Heres a pic of the board:
    Follow along with this guide: http://reprap.org/wiki/Rambo_firmware
    First thing I did was mark all my wires, just to be safe and to make the install a bit quicker. Once I had the RAMBo board powered and plugged into my computer, it was time for the drivers, which are located here: https://github.com/ultimachine/RAMBo...no_1.x.x/rambo
    It will most likely try to find them for you and when windows fails, select to find them yourself then direct it to the rambo/drivers folder.
    You will also need the most current version of Marlin:
    https://github.com/ErikZalm/Marlin/tree/Marlin
    So now that your computer is picking up the rambo board and you have downloaded the correct firmware, time to make a few adjustments to the firmware before we upload it...
    First change is the motherboard, change this to 301. Then you need to change your thermal settings to look like this:
    #define TEMP_SENSOR_0 1
    #define TEMP_SENSOR_1 0
    #define TEMP_SENSOR_2 0
    #define TEMP_SENSOR_BED 1
    (Make sure to plug the heated bed thermistor into the T2 pins(http://makergear.wikidot.com/m2-electronics), unlike RAMPs which uses T1 pins)
    (work in progress as of 2/16/14)
Tags for this Thread
