Thread: Autodesk Within
07-13-2015, 07:01 PM #1
Autodesk Within
Generative design makes use of a set of rules or an algorithm to create often parametric outputs. The acceptance of the process has ramped up as new programming environments such as Processing or scripting-based software such as Rhinoceros 3D have codified many of the principals of the style. Generative methods tend to be repetitive processes where a solution results from a number of design operations and iterations in sequence. Now with Autodesk Within, a set of generative design software solutions aimed at engineering, users can build and 3D print lightweight objects. You can read the whole story here: http://3dprint.com/80908/autodesk-within-software/
07-14-2015, 03:53 AM #2
Ender 3 Neo - Jam Problem
Today, 10:17 AM in Tips, Tricks and Tech Help
