Results 41 to 50 of 99
Thread: Post your scans here !
11-16-2015, 11:06 PM #41
- Aug 2015
- 12
Second and third scan. The second is a LG projector and the third one is a bottle of odor eater scanned using the other projector. Granted I won't know if it's accurate, just interesting if the projector ever goes out and parts aren't available, you can use another projector (assuming you put in the correct settings in the computer and projector).Projector medium.JPGodor.JPG
11-16-2015, 11:42 PM #42
11-17-2015, 02:52 AM #43Granted I won't know if it's accurate, just interesting if the projector ever goes out and parts aren't available, you can use another projector
That is interesting, and re accuracy, I assume there might be a parallax error, but, as the cameras are only seeing the patterns projected over the object, if you sit the projector over the other vertically, maybe when you calibrate it, it would self correct.
I did take my cover off and the projector unit is pretty well integrated with the cameras, and although your system works, it might be best suited to turntable scans aka fixed scanner positioning, as it'd be a heavy lump on the end of a tripod boom with a separate projector strapped to it.
Mike
11-17-2015, 03:58 PM #44
- Aug 2015
- East Sussex
- 10
Medium Detail.... Bright/Dark.... Turntable.... Object is approx 175mm long x 150mm wide x 175mm high.
Render Shepherd 1.jpgRender Shepherd 2.jpgRender Shepherd 3.jpgRender Shepherd 4.jpgShepherd Front Chair.jpgLast edited by Slack; 11-18-2015 at 01:16 PM.
11-18-2015, 11:57 AM #45
11-18-2015, 11:59 AM #46
11-18-2015, 03:15 PM #47
- Aug 2015
- 12
Yah definitely not for portability compared to the scanner. I was curious when you said you looked inside so I opened mine too. To my surprise everything was modular with normal connectors like USB to the cameras. Looks like easy to replace pieces and maybe a chance to upgrade the cameras. That face plate was super difficult to take off. I would not recommend it to people if they haven't opened something up before like a phone or tablet. I'm going to try to find cameras to upgrade this if the original camera supplier won't sell individual cameras. I want to make a base station for higher rez scans.
11-18-2015, 03:29 PM #48
As I'm on v1.7.1 now, and I see there is a v1.7.2 out on 3dker, I thought I'd do another test scan and a photo reference. It's only a one pass scan on the turntable (and if it had more steps the cavity detail would be clearer, less shadows to obscure the projected patterns), but the results are impressive, much better than the early software, so well done Shining 3D.
Mike
11-30-2015, 05:07 PM #49
- Aug 2015
- East Sussex
- 10
12-03-2015, 06:15 AM #50
- Aug 2015
- East Sussex
- 10
Turntable, Light/Dark, High Detail, 3 scans. Object is approx 180mm high x 140mm deep x 100mm wide.
Ender 3 Neo - Jam Problem
