Results 1 to 9 of 9
Thread: Warping with raft
05-01-2015, 08:09 AM #1
- Apr 2015
- 6
Warping with raft
Heyo, I recently got my hands on a FF Creator Pro. I've been working to get it dialed in with the ABS that was sent with it and I have been having pretty good prints so far. UNTIL this print. I've been getting warping on just one corner, at first I thought it was due to there not being a raft but once I reprinted with a raft it still continued to warp and even pulled apart some of the raft. The rest of the part printed really nice. Any suggestions?
05-01-2015, 08:20 AM #2
- Jun 2014
- Burnley, UK
- 1,662
I would suggest your bed is too low. That first layer is not mashed at all.
05-01-2015, 09:07 AM #3
I just had the same thing happen. I had printed 3 or 4 parts with no warping, but on my next print it started warping. I found my bed had gotten way out of level and had to level it. I restarted the last print I did and as of this morning the print was going great with NO warping(still had 2 hours left to go).
05-01-2015, 09:10 AM #4
- Apr 2015
- Chicago
- 42
How often are you guys finding you need to re level the bed?
05-01-2015, 09:21 AM #5
I will check mine every 5 or 6 prints. it just so happens that I had cleaned the bottom of my machine and had bumped one of the wing nuts and knocked it out. Does not take much. I did not check the bed after I bumped it and it had knocked it out by about .3 mm. I say check it often.
05-01-2015, 11:53 AM #6
- Apr 2015
- Northern Ohio
- 198
05-01-2015, 12:04 PM #7
- Apr 2015
- 6
Huh, alright Ill give bed re-leveling a try. I also had someone on reddit say that he was having a similar problem and said he fixed it by printing disks like this around the corners but that seems like kinda a lazy fix. Also I've been printing with the print bed cover tape that it comes with and its been working pretty well for adhesion. Even on this print the part that was failing wasn't the bond from the bed to the print but actually the layers of the raft. And lastly in response to Mjolinor, I don't think the bed is too high because it prints close when I don't use a raft but but I might need to adjust the raft settings so that it is lower. Ill try reveling and post an update sometime this weekend/early next week.
05-01-2015, 01:55 PM #8
- Mar 2015
- San Diego, CA
- 107
05-01-2015, 04:39 PM #9
- Apr 2015
- Northern Ohio
- 198
If you are using that then there are some issues. I cannot get my parts off that material without almost breaking them. The leveling is a start as it sets the distance from the bed. What slicer are you using? If you can set the bed temp to 110 for the first couple of layers then back it down to 100. Same for the extruder. Start at 230C and then back it down to 220 or so. You have to play with a new spool to figure it out. I run a 90% first layer height with 125% width
ABS and other materials vary with color and manufacturer.I have a couple of small test parts that I created difficult geometry for knowing that they will work for larger builds due to their difficulty. When I load a new spool I run these parts to see where I stand settings wise for that roll.
These things can help with the leveling
http://www.amazon.com/JW-Winco-Knurl...words=M3+knobs
You really only need a .004 from what I found but I use them for other things.
http://www.amazon.com/Precision-Bran...l+feeler+gauge
