Results 21 to 30 of 32
Thread: SgtToe 12" i3v Build Thread
04-02-2015, 12:32 PM #21
- Apr 2015
- 9
Nice. Yeah I'm really excited about the 12" print volume but a little nervous that I'm not going to find a convenient place to put it. Meaning I'll likely have to calibrate every time I go to print something. Who know's though, maybe she'll find a use for it too and then I could just leave it in the living room .
04-06-2015, 10:26 AM #22
- Feb 2015
- Flagstaff, AZ
- 73
Ok, this next step has me a little nervous. I just finished assembling the extruder and now the directions tell me to hook the rumba board up tot he heater and the thermister in the hot end and bring it up to 220c and then tighten it.
1. So did you guys skip this step and come back to it when you had all your electronics mounted and hooked up? And to I need to have the heat sinks on the stepper drivers before I apply power to the rumba board at this point or just before I actually try to drive motors with it?
2. What did you set the hot end on while it was heating up?
3. Any other advice around this step other than don't get burned? lol
04-06-2015, 10:51 AM #23
- Feb 2015
- Miami
- 12
It was scary but not difficult at all. I used the glass that I had cut for the bed to place the hotend on while it reached temperature. Then grabbed an adjustable wrench and tightened it up. Be careful when tightening the heater block as it is easy to mess up the threads with the wrench supplied. Tightening the nozzle is simple.
04-06-2015, 11:04 AM #24
- Feb 2015
- Flagstaff, AZ
- 73
did you do the steps in sequence so that the electronics were only hooked to the thremister and the heater or did you come back to this step once you had all the other electronics hooked up? Was you glass already on your bed? I was worried that it would damage the glass or the heater under it if I had the hot end resting on the glass.
04-06-2015, 11:31 AM #25
- Mar 2015
- Palo Alto
- 63
You don't need anything else attached to the board other than power, thermistor, extruder heater cartridge and some way to control the nozzle temperature (LCD or USB with pronterface [or other software]). You are not using any motors so stepper driver heat sinks are not needed.
I put the nozzle in a small metal vise to hold while it was heating, but that is just because I had one handy. Glass will certainly not melt and shouldn't scratch or anything. My only worry there would be too fast local heating/cooling.
I actually did do mine out of sequence, but only because I finished the build while waiting for my power supply to arrive.
04-11-2015, 11:48 PM #26
- Feb 2015
- Flagstaff, AZ
- 73
First print underway! It is late and I just grabbed some of my wife's hairspray, corners look ok, i think one might be lifting, plan to get some purple gluestick, this is Garnier Sleek and Shine Extra Strong #4. I'll post more pics when it finishes and seek advice on tweaks.
04-12-2015, 12:34 AM #27
- Feb 2015
- Flagstaff, AZ
- 73
Finished! There were a few dark specks that seemed to come out of the extruder but other than that I think this is a decent looking first print. All I did was level the table. I think I need to calibrate the extrusion rate next, any other ideas or recomendations? Is this quality good enough for me to print all the printable spare parts for the the I3v?
Lastly I noticed this goober on the bottom of the extruder, is that normal?
Oh and do I need to apply hairspray or glue stick before each print?
04-12-2015, 07:26 AM #28
- Dec 2014
- Canada
- 498
how accurate are the dimensions? and yes goobers are normal in my experience
you only need to add hairspray/glue if stuff isnt sticking. also sometimes you can shift the XY Start position so its not always starting at the same location where the hairspray/glue might have worn out.
04-12-2015, 09:53 PM #29
- Apr 2015
- Lakeport, CA.
- 174
Congrats on the successful print!
Within the next few days I'm hopefully ordering either the 10" or 12".
04-13-2015, 12:32 AM #30
- Feb 2015
- Flagstaff, AZ
- 73
