02-10-2019, 06:41 PM #1
- Feb 2019
Best program for designing a PC case?
I was wondering if there where any programs out there which where good for designing PC cases?
I've gotten as far as I can with tinkercad but now im at the stage where i've got to align the case to ATX power supply fittings and motherboard standoff/rear IO panel/PCI slots... and it's tough. I was wondering if there was anything out there which had templates or something which makes the process easier?
Also if there's a quick way to enter drill/bolt holes & fittings, that'd be useful?
If not can someone point me in the direction of a place which might have a EATX motherboard tray template which I could buy/download please?
02-11-2019, 05:21 AM #2
quite a lot of pc cases on www.thingiverse.com
can't help on the cad as I only use openscad.
03-02-2019, 05:10 PM #3
- Mar 2019
thanks a lot i try that its so cool
05-31-2020, 07:04 PM #4
07-04-2020, 01:40 PM #5
- Aug 2017
- Bold Springs, Georgia
Any of the high end software, Solid Works, Solid Edge, inventor, etc. If you can afford..
07-15-2020, 12:33 AM #6
- Jul 2020
i will definitely try this... thank you
07-22-2020, 05:51 AM #7
my best homemade 'pc case' is a piece of plywood. With hole drilled to mount the motherboard and a power supply attached with a bracket.
Super cheap, really compact and with amazing airflow !
In fact I even added network switch and turned it into a tiny dedicated server for my laser cutter :-)
All in the space of a sheet of A4 and about 4 inches high.
