12-06-2014, 10:35 PM #1
- Dec 2014
Question about leveling an object on the print platform in Cura
HI I am a newbie but I am getting a pretty good grasp on everything except I am having a problem with a couple parts I had designed
by an engineer/ He sent me the STL files and I am able to import them in to Cura to create a GCode however I can not get it to lay flat on the
platform. See photo.
Does anyone know how I can make this work?
I have tried using the rotate function but it is limited.
12-07-2014, 01:29 AM #2
There are a couple of things you can do that you may not have found.
1. Click on the object and in the lower left you'll get transformation icons. The leftmost one is 'Rotate.' Click on it and you'll get two more icons that fly out above it. The top one is "Lay Flat." See if that corrects the model for you.
2. After you've clicked on the model, it will have transform gizmos around it. Find the one on the axis you want to rotate and while holding 'shift' left click and drag. You'll be able to drag in 1-degree increments.
3. Get a free program like MeshMixer and import your .stl. Rotate it and save it back out.Bambu P1S/AMS
12-07-2014, 10:26 AM #3
- Dec 2014
Do bed magnets deteriorate.
