Results 1 to 10 of 13
Thread: Part has lots of webbing
11-12-2014, 06:53 PM #1
- Nov 2014
- 12
Many of my parts have "webbing", I'm very new at this and correct me if theres a better term but I'm not sure what it is or why it does this?
Makerbot mini
Filament by Makerbot
Is this normal?
Is there another name for this or is it webbing?
11-12-2014, 11:16 PM #2
- Aug 2014
- Montreal, Quebec
- 576
Some call them artifact, I call them christmas garlands.
Anyways it is normal, but for your specific case, no. The retraction calibration is pissed poor as hell. Heck I can't understand how makerbot can sell you something without half decent configured. Anyways, the trick is to play with the temperature. The hotter is your hotend, the easier plastic will leak while jumping from a spot to another.
You can solve by reducing the printing temperature. Alternatively if you can, play with the retraction speed or retraction distance.
11-14-2014, 07:54 AM #3
This is caused by an off calibration in your retraction rates combined with a slightly off melting temperature I think. Your part looks pretty warped from heat (unless the top is meant to be wonky, sorry if it is)
Set your retract to be a little faster, and retract more filament than it currently is. I would lower the printing temp you are printing. I assume thats PLA from the super shiny look? what temp are you printing at?Hex3D - 3D Printing and Design http://www.hex3d.com
11-14-2014, 05:26 PM #4
- Nov 2014
- 12
Thanks Richard and Geoff,
PLA yes
I cant play with the Temp, the tab is grayed out and cant be changed, I cant even turn off rafts
The mini gives little options
I don't see any "retraction speed"
For my case do you mean "Speed while traveling" or "Speed while extruding"
Should I increase or decrease?
Here is my settings panel, as you can see temp is grey
Thanks again, it means a lot, Ed
11-14-2014, 06:09 PM #5
I strongly suggest getting Proftweak, it lets you fix the lack of makerware settings, and is mac compatible..
http://nothinglabs.blogspot.com.au/2...e-profile.html
From memory there is no retraction setting in there but there is many others that will probably let you fix your issue.
The thing that is seriously confusing me is why your temperature tab is greyed out, this might be a bug I think my friend, #1 thing you do when printing is set the temp (to all different settings.. depending on plastic) so to have it greyed out is a concern and I'd want to get that sorted first.Hex3D - 3D Printing and Design http://www.hex3d.com
11-14-2014, 07:12 PM #6
- Nov 2014
- 12
Tried the app, thanks,
Changed Temp
230 -> 220
Changed Retract Rate
25 -> 30
does that sound okay?
Screen Shot 2014-11-14 at 8.18.58 PM.jpgLast edited by gencode; 11-14-2014 at 07:19 PM.
11-15-2014, 12:55 AM #7
If it's PLA, you can go all the way down to 180c probably, personally I would try at 200c and see the result. If it sounds like its straining or clicking at all, raise it of course but see how you go at 200c. The cooler it is the less goopy and the less spider webbing also. 200-210c seems to be what I print most of my PLA at these days, with very small variances like 205c.. or 195c...
On a Big model, I would set my retraction to around 30-40ms and the extraction amount to about 2.0
On a REALLY big model probably a higher extraction amount like 3.0. The small things you print only require a small retraction usually and you can do it pretty fast, like 40-50ms.Hex3D - 3D Printing and Design http://www.hex3d.com
11-15-2014, 06:47 AM #8
- Nov 2014
- 12
You guys are totally the best!!! I tried 220 and it did not work, changed to 200 and there is very very little webbing, ill try 180 next
Its a different part, but this one had the exact same issue and now there are little threads, before it was thick spider webs like on the other part.
Geoff, I do have a question, since lower seems better, sounds like I should just keep lowering till the webs are gone and stick with that, are there any advantages to higher temp? stronger etc?
Since there are no odd noises at 200 maybe I can get this last bit of webbing out by changing to 180c
Currently I am using this and the webs are almost gone.
extruderTemp: 200
retractDistance: 2.5
retractRate: 35
11-15-2014, 01:58 PM #9
Glad it's improving. The 180c will all come down to the plastic, some will melt that low, some lower and some wont melt till a good 200c... . You may still get webbing at 180c, but it wont hurt to try at all- the worst you will get is 'click click click'
As you probably saw the retract is what happens everytime it needs to stop printing and move to another area to start printing. If it does not retract enough and fast enough, it will leave the spider web when it moves.
So the webs are caused by a few things, speed being one of them. So in the next set of tests, besides the lower heat, try lowering the travel speed (too fast and it will web! )
So for the next one try perhaps
190c
retract distance 3.0
retract rate 40
Print speed about 50-60ms
Travel speed try 90ms.
This might be a bit slower, but better to find out whats causing it , and then improve that thing rather than everything.Hex3D - 3D Printing and Design http://www.hex3d.com
11-15-2014, 11:41 PM #10
- Nov 2014
- 12
I tried these
and it did not work out well
Changing to your suggestion of 2.5 and 35 to see if any improvement
I dont see a Print speed or Travel Speed
