Thread: ABS adhering to HIPS
11-11-2014, 11:43 AM #1
- Nov 2014
Has anyone else had bad experiences with ABS adhering to HIPS support material? Seems like when HIPS is used for a support layer, ABS doesn't want to adhere. I've been experiencing a lot of curling and filament drag across my parts. Any suggestions?
Printer/model setup:
Airwolf 3D HD2X
-Cura 14.09
-Repetier Host
-2.88 [mm] ABS from Airwolf
-3.00 [mm] HIPS from eSUN (sold by Lulzbot)
-Bed temperature: 125 [C]
-Extruder 1 temperature: 240 [C]
-Extruder 2 temperature: 240 [C]
-Layer height: 0.15 [mm]
-Print speed: 30 [mm/s]
-Platform adhesion: BRIM
11-11-2014, 04:58 PM #2
- Oakland, CA
- 935
Have you tried using PVA as a support material?
Andrew Werby
www.computersculpture.com
11-11-2014, 05:10 PM #3
- Nov 2014
I have not. I can order some, but I've only heard good things about ABS + HIPS. Surprised that it isn't working well...
11-11-2014, 05:25 PM #4
- Oakland, CA
- 935
It might help if you enclosed the build area and heated it a bit.
Andrew Werby
11-17-2014, 11:46 PM #5
- 349
Interestingly, I have not read of any good adhesion combinations for any materials.
11-27-2014, 02:35 PM #6
- Nov 2014
@pb3, this link from airwolf3d may help if you haven't already checked it out:
Compatible Dual Material Combinations
They link to their recommended ABS/HIPS settings, not sure if they match your settings above?
As for using PVA, according to the link above it's not compatible with ABS due to the higher ABS temp will melt the PVA.
Also, I talked with Airwolf a couple weeks ago and they mentioned that they are getting better results using PLA as support to ABS rather than using HIPS. Here is how they are dissolving the PLA:
https://airwolf3d.freshdesk.com/supp...a-experimental-
Hope some of this is helpful. Good luck!
