Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Jul 2014
    not sure about 5-6 inches. But 3 is doable. Just have the object as two models and print the right side with the right nozzle and the left side with the left nozzle.
    You'll also need a slicer that lets you change the build plate dimensions. Simplify3d does. Not sure how easy it would be to do with anything else.
    But yeah printing in two parts and joining would be much easier :-)
  2. #12
    bl099
    Guest
    Quote Originally Posted by curious aardvark View Post
    yes you can increase it on your own. Without rebuilding anything or changing your motherboard. Sometimes geoff overlooks the easy - ducttape world - option because the hard option is easy for him :-)
    Bear in mind that the whole width of the of the machine is not used because the specs are given so that both heads can reach everywhere on the build plate.
    All you need to do is drop a wider plate (3mm glass or aluminium would be fine) onto the existing one and use a cold bed plastic like nylon, pet, pla etc. you can then use the right head to just print stuff on the right and the left head to print on the left.
    I haven't measured it but I reckon another 5-6 inches of width would be easily achievable.
    Not sure if it'll print with more depth. But you could probably squeeze a bit more depth out if you wanted to.
    Easy way to check is to move the printhead as far forward as it'll go and see if it's gone past the end of the printbed, if it does then there's your extra print depth :-)
    That's the easy bit. The hard bit is getting the software to use the new width of the build plate.
    I suspect you'd need to start using a fullly compatible 3rd party software like simplify 3d. Not sure if makerware or repg will let you designate a larger printing area.
    Proftweak might.
    I know this is an old post but potentially I can put on a sheet of aluminium, and be able to print bigger objects? Does the actual 3D printer?s firmware need changing?
  3. #13
    Jul 2014
    potentially, yes - and move the end stops..
    For my rep clones I use flashforge's flashprint these days, just so much better for the dual nozzles than simplify3d - and I've yet to find any way of changing bed size on it.
    I've looked as I'd quite like to use it for other printers as well.
    You could do it using simplify3d, or cura or slic3r.
    But not flashprint or makerware - that I know of.
  4. #14
    bl099
    Guest
    Sorry. I am a newbie. How do you go about moving the finder?s end stops? Thanks.
  5. #15
    Jul 2014
    on a finder ?
    no don't think yu can enlarge the print area on one of those. This was all about doing it on a creator.
    Quite different machines.
Tags for this Thread
