Thread: Ender 3 s1 Pro weird behaviour
01-16-2024, 03:11 PM #1
- Jan 2024
hi all.I have an Ender 3 s1 Pro running a Sonic Pad with Klipper firmware.When I send a print job which is wide and flat it doesn't print well without a raft. With no bed adhesion or with a skirt or brim I get nozzle dragging, lumps and bumps and general bad results.If I print the same design on a raft it comes out perfect.I do manual tramming at temp (60 degree bed and 200 nozzle) with a 0.1mm feeler gauge before a 100 point auto bed levelling. Standard settings in Cura with only the addition of a raft.Creality PLA filament, just opened.what's going wrong?
01-16-2024, 03:22 PM #2
- May 2020
- 620
Try increasing the 'Z' offset by +0.01 or +0.02.
Clean the bed with some IPA before printing
01-16-2024, 03:35 PM #3
- Jan 2024
Ok, I'll give that a go and report back tomorrow - currently printing my son a space shuttle! (On a raft!)
01-17-2024, 02:18 AM #4
- May 2020
- 620
You could also try increasing nozzle temp by 5 degrees.
Perhaps you could have a look at Prusa slicer, there is a configuration profile for your printer in it.
01-17-2024, 03:53 AM #5
- Jan 2024
As you can see, the bottom few layers look messy where the nozzle dragged. Side walls look great. Top is a bit scrappy. I'm going to try e-steps next to check over or under extrusion.
