05-22-2023, 05:22 AM #1
- May 2023
Print has "unwanted lines" on TOP layer
Hi all, I started with 3D printing not long time ago. I came across a small issue which you can see on the picture. This particullar print has those few "unwanted lines" on the top layer. Any suggestion what could be the cause?I have Anycubic Kobra Max and using Cura slicer.Thanks a lot
05-22-2023, 05:47 AM #2
- May 2020
- 614
Try 'Z' hop on layer change, just something to try, it might work.
There should also be a command in the slicer to avoid moving over printed parts.Last edited by Bikeracer2020; 05-24-2023 at 01:22 AM.
