04-13-2023, 06:04 AM #1
- Mar 2023
mks nano robin v3.1 to ts35 v2.0 flat cable extension
Hello to all, I am fairly new here, an am upgrading my old geetech g2spro 3D printer on many issues point, but mainly building a mks nano robin v3.1 into an more sturdy MDF external frome in which the old geetech frame in incomporated making it extremely sturdy. To do so i need to extend the 2 flat cables from the board to the ts35 display. I made my own flat cables from a 10 wire roll of rainbow wires and 10 pin flat cable connectors but something strange is happening. When I use both cables extended, i get a white screen. If I use one extended cable and one original cable it works fine, no matter which of the cables is short and which is long and also which of the 2 (actually 3 as I made an extra) long cables I use. Does anyone have tought on the logic of this issue? Kind greats. I still have to verify each new cables pins, but as it doesn't matter which cable I use I believe there shouldn't be an issue there. additionally, does anyone know where to find the pinout of these connector cables, to check the function of each pins. Kind greats Matthieu
04-15-2023, 08:21 AM #2
- Mar 2023
I verified the extended cables and they are all fine, normal continuity, no shorts between the leads. also the extension in not much, standard 0,5m to approx 1m.
Do bed magnets deteriorate.
