Results 1 to 8 of 8
  1. #1
    Student
    Nov 2022
    Location
    Southern Utah
    Vertical walls not sticking to one another
    I am fairly new to 3D printing and not sure what the correct terminology is. The problem I am having is that my walls (perimeters?) are not sticking to one another. At the top of any wall, I can run my fingernail across the top edge and pull the wall sections apart. See the image for an example. I think the issue could be under extrusion but I have tried the print on two different printers, and one of them is almost brand new and has a micro swiss geared direct drive. Both printers give me the same results. I have tried several things like slowing the print down, increasing the temperature of the PLA, changing wall thickness, changing z-seam to "shortest" - I have tried the same 3mf and stl files on both Cura and PrusaSlicer. I am at a loss for what is causing this to happen. Has anyone had this happen before? I am creating my files in Fusion 360. My two printers are an Ender 3 pro and an Ender 5 Plus. Thanks in advance for any help.
  2. #2
    Technologist
    Jun 2022
    Location
    The great state of Texas
    Do you mind sharing the stl file? I am curious if there is anything going on with it since you have tried different printers with different settings.
    I have not had anything like that behavior in my printer, though I have only been 3d printing for about 4 months.
  3. #3
    Student
    Nov 2022
    Location
    Southern Utah
    Here are the files. I have included a 3mf, gcode, and stl(binary).
    https://drive.google.com/file/d/1GK6...ew?usp=sharing
  4. #4
    Technologist
    Jun 2022
    Location
    I wish I was more help.
    The file looks fine. I threw it into my machine and it printed fine.
    Here are the settings I used on CURA and a picture of the print. Sorry, best of luck. Hopefully someone has the answer.
  5. #5
    Student
    Nov 2022
    Location
    Southern Utah
    OG56,Thanks for tying the files out. While it may not solve the problem, it makes me think that the issue is with the printers. I will try and find something similar online to test print and see if I still get the same issues.
  6. #6
    You might need to use supports for a over hang like that and also maybe level the bed Have a great day
  7. #7
    Super Moderator
    May 2020
    Quote Originally Posted by 3DPrinterMan1234 View Post
    What overhang? I don't see any overhang.
  8. #8
    on the inner side of the box where the wall is coming off
