Thread: How to repair stl
05-01-2022, 09:09 AM #1
- Feb 2022
- 7
How to repair stl
Hi. How to repair a damaged stl Meshmixer and 3D Builder can't fix it. It is not very visible in that photo, but there are omitted parts of the lines. Slecer I use Simplify3D.
05-01-2022, 03:22 PM #2
- 887
Do you get displayed error indicators in Meshmixer from the file? If you can post the STL, it might be easier to determine a solution than to attempt so from a photo.
05-01-2022, 05:27 PM #3
- Feb 2022
- 7
Does not display Meshmixer errors. This is a problem I've come across several times. Cura can fix these bugs but fails Simplify3D which I use in which supports well. Since most printers use Cura, they don't know about these defects. I tried to ask, Thanks.
05-01-2022, 05:37 PM #4
- 887
Do you see in the slicer the flaws that appear in the photo? It's difficult to determine from the image what you are determining to be failure points.
05-02-2022, 04:27 AM #5
- Feb 2022
- 7
The slicer does not show these defects. I searched the internet and these are known defects. Microsoft STL Repair has provided fixes for these defects, but this option is no longer available.
