11-16-2013, 07:28 AM #1
Vitamin B2 (riboflavin) Helps create great non-toxic 3D Printed medical implants
This is great news for the medical field. 3D Printing has been being used for a while for implants, but it's difficult to prevent the human body from rejecting the materials. Apparently now scientists have found that Vitamin B2 is the substance that needs to be used, to prevent this.
Another light-based 3D printing breakthrough uses a non-toxic material for medical implants and other devices.Researchers from North Carolina State University (NC State), the University of North Carolina at Chapel Hill (UNC) and Laser Zentrum Hannover (Hannover, Germany) have discovered that a naturally occurring compound can be incorporated into three-dimensional (3D) printing processes to create medical implants out of non-toxic polymers. The compound is riboflavin, which is better known as vitamin B2.
"This opens the door to a much wider range of biocompatible implant materials, which can be used to develop customized implant designs using 3D printing technology," says Roger Narayan, senior author of a paper describing the work and a professor in the joint biomedical engineering department at NC State and UNC-Chapel Hill.
The researchers in this study focused on a 3D printing technique called two-photon polymerization, because this technique can be used to create small objects with detailed features--such as scaffolds for tissue engineering, microneedles, or other implantable drug-delivery devices.
Two-photon polymerization is a 3D printing technique for making small-scale solid structures from many types of photoreactive liquid precursors. The liquid precursors contain chemicals that react to light, turning the liquid into a solid polymer. By exposing the liquid precursor to targeted amounts of light, the technique allows users to “print” 3D objects.
Two-photon polymerization has its drawbacks, however. Most chemicals mixed into the precursors to make them photoreactive are also toxic, which could be problematic if the structures are used in a medical implant or are in direct contact with the body. But now researchers have determined that riboflavin can be mixed with a precursor material to make it photoreactive. And riboflavin is both nontoxic and biocompatible--it’s a vitamin found in everything from asparagus to cottage cheese.
Do bed magnets deteriorate.
