  1. #1
    Help with print settings for ASA
    Hello, I am trying to print with ASA for the first time and having problems getting the desired result. I'm using
    • Dynamism ASA 2.85mm
    • Ultimaker 3 (I don't have any type of enclosure)
    • Latest version of Cura Using the CURA preconfigured "FINE" settings
    • With the following changes
    • Print Temp - 250f
    • Bed Temp - 80f
    • Print Speed - 40mm/s
    • Cooling - Off
    • Infill - 100%
    • Also using Magigoo original
    • Please help suggest what I should change in my settings.
  2. #2
    Super Moderator
    May 2020
    Quote Originally Posted by dudical26 View Post
    • Print Temp - 250f
    • Bed Temp - 80f
    • Cooling - Off
    • Infill - 100%
    Try bed temp around 95C.
    Drop your speed to 30-35. Slower is better.
    Preheat chamber with bed for a good 30 mins before starting print.
    On no account open doors until print has finished and everything is back to ambient temperature.
    Don't know about infil but I've never gone above 25%
  3. #3
    That's the good answer. Thank you very much super moderater.
    Stickman Boost
