Results 21 to 30 of 32
Thread: Printing issues
03-07-2022, 03:19 AM #21
- Jun 2014
- 887
that's good news.
03-07-2022, 04:39 AM #22
- Mar 2022
- Sweden
- 20
Test piece done
The measurment on the test piece in the program is... 105x105x5mm.When i measure it 104.5x104.5x4,95mmThe 104,5 measurment is measured on 3 places, close to corne and middle. They are 104,5mm all places.3 top solids and 3 bottom solids is the settings.And the thickness ,not the height on the piece is 5mm very good.So the extrusion width should be spot on , correct ? Why is there small holes on the top layer ??
03-07-2022, 04:43 AM #23
- Mar 2022
- Sweden
- 20
Should i have more extrusion width ? Its 0,4mm as the nozzle is.
Sorry .. its 4,85mm wide when i measure on different points.
Should i increase the extrusion width to get right size and more filling on the top layer or should i do it on another way ?
Im sure there are different ways but im leraning and i want to do the changes initially the coorect way/settings in the beginning.
03-07-2022, 07:59 AM #24
- Jun 2014
- 887
I've confirmed from the manual that you have a direct drive extruder. The next step is to check your e-stepper calibration. This is the value that the firmware uses to push the correct amount of filament from the nozzle, based on the slicer settings. Create a mark on the filament at the point it enters the top of the extruder. Measure and mark to another point at 95 mm from the first. Repeat this for 100 mm and for 105 mm. Using the machine control feature in Simplify3D, command an extrusion of 100 mm. Ensure that you have also directed the nozzle to heat to the correct temperature for the filament in use.
Observe the marks as the filament is extruded. The 100 mm mark should be at the same location of the 0 mark when the command is completed.
03-11-2022, 12:32 AM #25
- Mar 2022
- Sweden
- 20
Ok , but i cant find anywhere in the simplify3d where i cant just command 100mm extrusion. If that is wrong on my machine should i not step up/down the distance for example 65mm/s ?
03-11-2022, 12:37 AM #26
- Mar 2022
- Sweden
- 20
Strange issue
In the Simplifi3d i have change the offset to z-0,65mm and the thickness of first layer is correct.After thatThere is a choice of extruder calibration on the machine.When i check the calibraton i have z-2,34mm to much.It should be a paper that is about 0,07mm.In the Simplifi3d i have change the offset to z-0,65mm and the thickness of first layer is correct.
03-11-2022, 02:21 AM #27
- Mar 2022
- Sweden
- 20
Quality
The first layer ,, 0,15mm.. thats correct.The apperance does not look so good , should it not be more compact/melted ? The top layer should it not look more falt/melted ? The measurment on the cube now is 19.93mm and 19.88 on the sides. Thats is normal if there is a shrinks ?The nozzle .. 0,4mm... extrusion width 0,5mm
03-11-2022, 03:40 AM #28
- Jun 2014
- 887
Your first layer appears to have over-extrusion. What extrusion factor is in place in S3D?
03-11-2022, 03:42 AM #29
- Jun 2014
- 887
Also, if you have not confirmed the e-steps setting for the extruder, extrusion factor is irrelevant until you can confirm the e-steps. If you can't control the printer in S3D, consider to download Pronterface to provide direct control.
03-11-2022, 06:41 AM #30
- Mar 2022
- Sweden
- 20
What do you mean by e-steps settings ? How do i confirm them ? Is it the length 100mm that you wrote about ?
Extrution multiplier=1,00
Extrution width=0,5mm
Do bed magnets deteriorate.
