11-11-2021, 09:00 PM #1
- Sep 2021
- 12
switching from Cura to Prusa slicer, where is USB?
i've been having problems with my prints just stopping for no reason, and it always seems to be around 55% which makes me suspect a problem with Cura, but not sure. if it was a bad USB connection you would think the stop point would be more random.
anyhow, i've been thinking of trying prusa slicer for a while and just downloaded it. i see connection options for octoprint (which i don't have but probably a good idea) but not for USB. with Cura it's easy, just select to print USB. what's the dealio with Prusa?
i guess i need this https://www.pronterface.com/#download
seems like a pain to use yet another program, is there nothing built in?
thx
i should add, i'm using a ender3 and its worked perfectly for a month of so, then this random stop thing just started a few days ago and happens a couple of times a day. i do 20-30 prints a day so not all the time. i have the same hardware and software setup as before when it was fine.Last edited by steveh2112; 11-11-2021 at 09:14 PM.
11-15-2021, 06:13 AM #2
This was a removed from the rewriting of the core components, from what I have read.
However you can Use export to Octoprint
