01-30-2022, 11:07 PM #1
- Oct 2021
- 7
Can't change resin parameters in Lychee
All, I have tried to change the number of initial layers, the times and the subsequent layer times in Lychee, but for some reason when I print it always seems to print with the default Lychee resin settings. The printer is a Photon Mono X.I'm pretty certain it is me not understanding how to set it correctly and select it so any help would be appreciatedThanksLes
02-07-2022, 01:21 PM #2
Try chitubox
It will definitewly change the number of first layers for my proxima mono6.
Apparently some of these settings are hardwired into the printers firmware.
For instance: There are three movements per layer.
peel, secondary lift and then a quick bounce up and down.
I can't see any purpose for the third step, but no matter what settings I put in the slicer (tried 3 slicers) I cannot stop it doing the third up and down movement.
If I could eliminate it, it would cut the printing time almost in half, without having to change any other settings.
Do bed magnets deteriorate.
