Results 1 to 10 of 16
Thread: How do I draw this in 3d?
08-03-2021, 02:30 PM #1
- Aug 2021
Hi all, I'm a noob when it comes to 3D printing. I'm a mechanic and I want to design some very specific tools to make certain jobs easier and more consistent. We have a 3d printer at work and I want to start designing my own little contraptions so they do exactly what I want. The people responsible for the 3D printer aren't very experienced and I basically want to show up with a Usb-stick asking "could you just print this file for me?". Nothing fancy at all, just really basic parts. At the moment I'm trying to create a guide to help me cut plastic glue tips to a certain shape. I have done some 3d drawing in Sketchup in the past, but nothing overly complicated. I've also tried Tinkercad, Freecad and Fusion 360 but I just can't figure out how to create the object I have in my head.
In the pictures you can see the original part, the second picture is similar to the wanted result.
I want to create some sort of sleeve where I can insert the uncut glue tip, which is basically a cone. I want to have a guide to make the V-shaped cut. I need a surface to lay my knife against and make a controlled cut, holding the knife at a 45° angle.So far I managed to draw the original tip in 3D but I can't find out how to create the surfaces at the 45° angle onto the conical shape at the exact position I need. I'm pretty stuck at the moment and in need of some input from people who are better at this
Any ideas on how I should approach this design? Thanks for the help.
08-23-2021, 04:36 PM #2
- Aug 2021
- 6
hey, send me what you have and ill complete it
08-26-2021, 05:05 AM #3
- Aug 2021
Thanks for the offer. I can't find out how to share my file with you. I'm using the personal version of Fusion 360.
08-26-2021, 05:57 AM #4
- Aug 2021
- 6
Export it as an archive file. I think it's the top option. Save it locally then send me the file in a message bud.
08-26-2021, 06:14 AM #5
- Aug 2021
- 6
see attached bud
08-26-2021, 07:41 AM #6
Have you tried openscad ?
your part would take about 3 minutes and 4 lines to design.
Plus you could make it parametric.
For practical things openscad is probably the best and easiest to use.
You don't draw anything you just tell the program what you want and it does it for you.
With the added bonus that it only makes solid models that are suitable for 3d printing.
Does the v-cut in the tip go all the way through the tip, or is it just on the one side ?
The pictures really don't make it clear.
sketch-up - not so much :-)
08-27-2021, 04:02 AM #7
- Aug 2021
08-27-2021, 04:04 AM #8
- Aug 2021
08-27-2021, 04:09 AM #9
- Aug 2021
- 6
Could simply upload to your cloud and send a link..
08-27-2021, 06:16 AM #10
- Aug 2021
- 6
nozzle.jpgHows about that mate? That is an inner opening of 6mm with a 2mm wall. The V is then 6mm wide by 10mm long to the tip.
