Results 1 to 10 of 20
Thread: Garolite Mounting Question
06-21-2021, 07:48 AM #1
- Jun 2021
- 14
Hello all! New to the forum – And pretty new to 3D printing
I been reviewing the old threads but was unable to get an answer…
I recently started 3D printing and have been working with just PLA
I’d like to print Nylon to make some car parts (nothing mechanical, more like brackets for the engine compartment) that can handle more extreme temperatures
Current setup: Ender 3 V2, Microswiss Direct Drive and Hot end
Will be obtaining: Enclosure
Based on my research, Garolite shows the most promise…
My question is, what am I suppose to attach the Garolite to? Can I use Borosilicate Glass (if so, can I buy a stock Ender Glass plate and attach it to that)? Or am I supposed to invest in a flex plate like Buildtac FlexPlate system (seems a bit pricey so just want to confirm that’s the accepted method before getting it)?
Any other recommendation appreciated!
Also any Nylon Filament suggestion would be helpful, seems like I'm coming across alot of folks saying certain brands aren't actually Nylon even when advertised as such
06-21-2021, 10:52 AM #2
- May 2018
- 561
I have a Garolite plate I put on my Makergear M2. well I tired it out and was not impressed. It just sits on the heated plate after the glass bed is removed. You still need to apply glue stick and I have much better luck with Polymide tape on glass when I do use Nylon which is not often. Easiest to print is Taulman 910 alloy. PETG is does not warp as much as nylon and works well for things that need to be tough. Nylon is very flexible so that can be an issue if you need a rigid part.
06-22-2021, 10:02 AM #3
talk to gambo - he uses garolite in an ender 3.
And also prints nylon :-)
06-23-2021, 04:10 AM #4
- Aug 2020
- United Kingdom
- 249
Hey did someone call!fYes I have been using Garolite (known as Tufnol in UK) almost exclusivly for more than a year with all sorts of filaments. On my ender 3 I have a glass sheet on the heated plate - yes the standard Ender plate will do, The tufnol sheet I use is 1mm thick clamped on top of the glass plate. I use a thin sheet of tufnol so i can bend it to release models with Nylon sometimes the adhesion is very strongIn UK Tufnol can be bought cheaply from people like Trent plastics (https://www.trentplastics.co.uk/) I use the whale grade it is best to buy enough material for several plates because the tufnol is cheap but the carriage charges are more than the material for a single piece. Getting on to Nylon, first realize there are 2 distinctly different types of nylon, nylon 6/66 and nylon12 and a wide range of variation in the detailed chemistry for one reason or another. So all nylon filaments are not equal !! . Last year I tested 7 or 8 brands but could only reliably print with 3. Spectrum PA6 Low warp, Taulman 230 and Taulman Bridge. Both Taulman filaments give flexible results while the Spectrum filament is quiet hard and feels more like Delrin to use.If you would like to PM me I can give you more details of the machine settings I use.
06-23-2021, 04:53 AM #5
- Jun 2021
- 14
@airscapes
@curious aardvark
@Gambo
Thank you all for your feedback
Unfortunately I don’t know a product equivalent to tufnol in the US. It seems like tufnol is similar but not the same as Garolite? It also appears as if tufnol is some sort of stand alone sheet, whereas the Garolite here are sold with an adhesive backing (this is why I was asking about flexplate systems). I worry based on what Gambo stated, that over time, or even the first print, I’ll tear/damage the Garolite sheet off a glass sheet because of too strong of a bond to the print (they are 40 dollars a sheet here)
Currently I’m attempting to print Taulman3D 910High Heat:
Taulman suggest I use:
Print temp: 285C – 300C (check)
Bed temp: 45C (check)
Print Surface: Glass with PVA (this part is what confuses me given the inconsistent input I’ve read - which Gambo confirmed with what I suspected was nylon is a whole varying class of filaments)
Enclosure: (working on)
-Current setup:
-Ender 3 v2
-MicroSwiss Direct Drive and Hot end
-Fan Housing = https://www.thingiverse.com/thing:4408571 = printed in PLA
-BLTouch
-Firmware re-complied to have nozzle reach 295C (it appears that there is a hard limit of 299C to the nozzle that firmware can’t supersede –or I’m not fully understanding the marlin code)
-Filament Drier (upwards of 65C)
Task required before making Nylon Print Attempt:
-Enclosure and a Venting system to blow off the fumes
-Figuring out building surface (this one seems like the one I’ll have the most trouble with)
@Gambo
May I ask what your setup is on here? Or is it not the social etiquette to post such things here?Last edited by AsianGuy; 06-23-2021 at 05:08 AM.
06-23-2021, 09:33 AM #6
- Aug 2020
- United Kingdom
- 249
Tufnol and Garolite are the same thing SRBF for synthetic resin bonded fabric from McMaster- Carr.
The grade used by Taulman is Garolite LE grade but a cheaper grade will do cheap sheets are about $5-6 us dollars for a 12 inch by 12 inch sheet. You really don't want to stick it down to a plate clamp it to the Ender glass plate with document clips. 40 dollars for a stick back sheet of SRPF sounds like a rip off.
I print both Taulman Bridge and spectrum PA6 LW at 250 or 260C bedplate 50 or 60 C.
The upper limit for nozzle temperature is normally set either by having a PTFE lining at 240 260- which you don't have or by the upper limit of the thermistor NTC thermistors don't go beyond 285 or possibly 290 C unless you change to a thermo-couple type temperature sensor which can go way way up.
On the question of etiquette if the conversation is of general interest keep it on the forum but when you get into masses of detail why waste everyone's time.
06-23-2021, 09:39 AM #7
- May 2018
- 561
Another issue with Nylon is it sucks water like a sponge, so be prepared to dry it before every use even stored in vacuum bags..
06-23-2021, 06:34 PM #8
- Jun 2021
- 14
@Gambo
I’m clearly confused what Garolite is. I tried searching for “SRBF” and “synthetic resin bonded fabric” on McMaster-Carr and the items doesn’t appear to be what I’m looking for. I agree, 40 is very pricey, but I haven't developed a smell test on what the expected prices on things are.
Given what you said about LE grade, would something like this work?:
https://www.mcmaster.com/garolite/easy-to-machine-garolite-le-sheets-and-strips/
If so, and I buy a 12”x12” (or even 24”x24”) sheet, can these materials be cut to dimension (235mmx235mm) with a xacto knife/razor blade? Would cutting it affect its performance or “flatness”? Additionally, if this is the material, what thickness should I be aiming for?
I was able to reprogram the firmware to lift the upper cap of 260. I had attempted to bring it to 300, but at exactly 299, for three iteration, I got a nozzle too hot error. This led me to reprogram the firmware to only go up to 295. I’m unsure of the nozzle temp needed, as I don’t have everything I need for my first nylon attempt yet, but I’m just going off the spec page from Taulman’s which claim their 910 heat nylon should be printed at 285-300. I’m not an engineer by trade and I’m not well versed on the various components of the 3d printer, but can follow instructions very well. So while I functionally understand what thermistor and temperature sensor does, the deeper nuances are lost to me. Is it safe for me to print at 295 with the stock thermistor and temperature sensor on an Ender 3 v2? Or would I need to research upgrading them to avoid a short or burn out?
@airspaces
I’m converting a food dehydrator into a filament dryer/holding box while printing. The dehydrator is rated for 70C. My plan was to dry it for 12 hours at 65C prior to attempting my first nylon print.
I have to do some research on what vacuum bags to use during storage. It seems the ones I’ve encounter so far have complaints about punctures. I’ve also considered food saver vacuum systems, but it doesn’t appear as if the community has co-opted this the same way they had with food dehydrator.
Thank you all the feedback!
06-23-2021, 06:59 PM #9
- May 2018
- 561
Your dehydrator is perfect it is what I use. The bags I use don't last but a few uses and I get them at the dollar store when they have them in stock. They last longer if you put the spool in the plastic bag it came in and that in the vacuum bag. I did fine smaller ones on ebay that fit better but were a few cents more..
The 910 comes in 2 flavors.. the original and high temp.. The original is 250-255 https://taulman3d.com/alloy-910-spec.html
The Garolite I have I bought from a machinist on the MakerGear forum for $50. He made several for himself and was selling them. He milled it smooth (not as flat as the glass plate but close). It still needs glue stick for nylon to stick and you can not go over 80C on the bed or it will warp, which means I can't print ABS on it and I hate changing beds and redoing Z offset. So you may want to just try some polymide tape on your glass plate and put a little glue stick on it.. Lot cheaper and works well. None of the nylon I have printed needed to be printed over 260C. BTW Garolite is Fiberglass https://www.google.com/search?q=what...hrome&ie=UTF-8
Garolite is the brand of G10 so search "G10 sheet"
Polymide bed tape here https://www.makergear.com/products/polyimideLast edited by airscapes; 06-23-2021 at 07:04 PM.
06-23-2021, 10:59 PM #10
- Jun 2021
- 14
@airscapes
I’m looking specifically at the Taulman 910 high temp one. I’m looking to print a number of parts for various other hobbies, but one part will be a bracket that’s going in the engine compartment of a car. Therefore I am aiming for the high temp version – it’s said that they have a 150C thermal resistance after annealing. There is the Taulman PA Cast Plate Nylon, with a supposed 185C thermal resistance after annealing, but since the filament is so new, I can’t get much confirmation or information about it.
The Polyimide tape appears to show some promise, but cover a glass plate with a narrow roll would leave lines on a printed model’s surface?
Something like this:
https://www.makergear.com/collection...20387220586594
seem better, but then it starts getting into the price issues since I’d have to cut it to size (235mmx235mm)
Has anyone printed nylon on glass with just PVA? I know Taulman suggest that for their filament, but it doesn’t appear like anyone I encounter on forum or YouTube does that.
