Results 1 to 10 of 12
05-12-2021, 05:31 PM #1
- Apr 2021
- 30
problem with z axis on tronxy x5sa pro
Hi, the two Z motors run without without turning the axis bars. I tried to tighten the screws but don't block the axis. How can i fix?
05-12-2021, 07:35 PM #2
- Apr 2021
- 186
Need more information.
When they run, do the motor axles turn, or does it cause a chattering noise (missed steps)?
Is the bed (and bed support carriage) tilted at all, or is it fairly parallel with the frame?
05-13-2021, 03:29 AM #3
- Apr 2021
- 30
the motor axes turn, doesn't cause chattering noise...the bed is parallel with the frame..but doesn't move when motor runs
05-13-2021, 04:31 AM #4
- Apr 2021
- 186
Ok. Do the threaded rods move? If not, have you tightened the couplers so they are properly holding the motor axles and threaded rods?
If yes, then take a photo and post it.
05-13-2021, 05:07 AM #5
- Apr 2021
- 30
fixed the problem! a few screws had entered the pulley... at the first calibration there were some clicks on the axes but now the plate has arrived on top .. what should I do? it's my first printer...edit: i went to z offset. the head has scratched the bed....calibration it's ok.Now the problem is when i try to print file on microsd.The first layer doesnt stick on the bed. How can i fix ???
05-13-2021, 06:05 PM #6
- Apr 2021
- 186
I am afraid I can't remember how the X5SA pro's bed calibration works. I haven't used it for months.
05-14-2021, 06:56 AM #7
- Apr 2021
- 30
I was successful in the calibration. Now the problem is that the shapes are bad. The squares are then flattened into a rhombus shape..
05-14-2021, 07:19 AM #8
- Apr 2021
- 186
Good work. Can you post a picture of the skewed prints and your printer showing the belts.
05-15-2021, 08:31 AM #9
- Apr 2021
- 30
https://imgur.com/Ad9cArs and https://imgur.com/14O5LkM . What is wrong?
05-15-2021, 08:36 AM #10
- Apr 2021
- 186
Got a photo of the entire belt system?
Are both belts tight (and equally tight)?Last edited by Martin_au; 05-15-2021 at 09:02 AM.
