  1. #1
    PrusaSlicer 2.3 settings for Ender 5 plus.
    Hi.Please I have a problem with the lower layers of the printout and I don't know how to set up PrusaSlicer 2.3 correctly. Chip 0.4 does not place individual fibers next to each other but with a gap. The filament is PLA, the nozzle temperature is 220 ° C and the table temperature 55 ° C.
  2. #2
    Jun 2017
    Location
    Washington State, USA
    Looks to me like you are printing the infill with a percentage. this could be normal.
    To correct choose infill as solid or at least above 75%.
  3. #3
    Hi.
    It's still the same, nothing has changed,
    Thank you for answer.
  4. #4
    Jun 2017
    Location
    Did you download Ender 5 plus using.
    Select Ender 5 Plus 3D Printer
    Click Configuration > Click Configuration Wizard ...
    Click Other Vendors Check the box Creality select Creality Ender-5 Plus to download Ender 5 Plus profile.
    Then
    Select Filament's you may use on your Ender 5 Plus 3D Printer
    Click Filaments > Select Creality Ender-5 Plus and select (ALL) Types and (ALL) vendor then select all filaments you may be using.
