Thread: ReplicatorG and support material
07-28-2014, 03:24 PM #1
- Burnley, UK
- 1,662
Is there a way to use one extruder for support and the other for model. I have 3 full Stratasys breakable support cartridges left over from a printer I sold and it is really good to remove as it is very brittle. I would like to use it with my Wanhao but cannot find a setting anywhere to make the printer use one extruder for support and the other for model.
It has to be there somewhere.
07-28-2014, 10:21 PM #2
- 349
I think you just have to manually set the temps different for each one.
07-29-2014, 03:43 AM #3
- Burnley, UK
- 1,662
Temperatures of the breakaway are the same as the ABS, it is how to make it use the other extruder that I can't figure out. It is not easy manually either as there is no separation in the Gcode for support and model, the layer does not change.
