Thread: Replicator 2x phantom part
03-14-2021, 06:45 AM #1
- Mar 2021
IMG_1488[1].jpgHi there, my Replicator 2x is printing fine but has started printing additional geometry. With every part I print a separate ‘L’ shape of wall is built to the height of my geometry.Can anyone tell me where this has come from and how to get rid of it?Thanks in anticipation , Theo
03-14-2021, 10:54 AM #2
- 887
what slicer program do you use? Look for settings in the same area as raft, support, brim, etc.
03-14-2021, 11:32 AM #3
- Mar 2021
03-14-2021, 11:57 AM #4
- 887
Purge walls and equivalent-named features in a slicer is how a multi-material printer clears the nozzle of the previous color or material.
I'm not familiar enough with your printer to ensure that my suggestions are valid, but Prusa makes a top-notch free slicer program. Many users will have Cura as the slicer, but I have found that I do not particularly enjoy the interface.
03-15-2021, 02:46 PM #5
- Mar 2021
Hi Fred
Thank you for the sound advice and information
Much appreciated
Kind regards
Theo
03-22-2021, 01:30 PM #6
best slicer for a rep 2x is Flashprint.
On install select: creator pro.
Sooo much easier and better than the makerbot nonsense :-)
https://www.flashforge.com/download-center
The only other slicer you could use is simplify3d. But to be honest, for the rep 2x flashprint odes a better job. Also real easy to do dual extrusion.
Your printer uses x3g files and those are - as far as I know - the only slicers that support x3g.
The purge wall is for when you are printing with both extruders.
It ensures that when you change from one extruder to the other that all the plastic is purged (hence the name) from the nozzle not being used. Otherwise it tends to dribble over the print.Last edited by curious aardvark; 03-22-2021 at 01:37 PM.
03-23-2021, 04:58 PM #7
- Mar 2021
Hi there, thank you for the advice. It would be great to use a better slicer as I'm finding the Makerbot Desktop a bit limited, I will give Flashprint a try - many thanks
