  1. #1
    Ender 3 pro - newbie wall gaps issue
    Hi all, first print, first post!
    Ender 3 Pro, Cura slice software
    159175218_288363449304405_7447153906461391998_n.jpg158430527_1880663902083297_4580687090963789250_n.jpgScreenshot 2021-03-13 210241.jpg
    I’m getting these gaps in my walls (they’re supposed to be flat vertical) and I can’t really find a similar example on the internet to refer to and tweak my settings.
    Initial layer height: 0.24
    Layer height: 0.2
    Print speed: 80
    Initial layer speed: 30
    Retraction: 6 / 25
    Not sure if there are any other settings you’d need so let me know.
    I presume this is a newbie issue so hopefully someone can give me some pointers. Thanks in advance!
    Ben
  2. #2
    Jun 2017
    Location
    Washington State, USA
    What is you infill percentage set to.
    This looks vaguely familiar.
    Set your perimeter "vertical shells" to 2 or 3 walls printing perimeter first followed by printing infill with overlay to .025
  3. #3
    Hi thanks for the reply. Infill is 50%. I’m not familiar with those other settings but I’ll have a dig and see if I can find them!
  4. #4
    I can't find anything referencing vertical shells or overlay in the Cura settings - any ideas?
  5. #5
    Jun 2017
    Location
    It has been a while since using Cura mostly use PrusaSlicer 2.3.0 now.
    Looked In Cura 4.8.0 and it is called Infill Overlap Percentage and Infill Overlap
