01-26-2021, 03:28 AM #1
- Sep 2020
- 4
Advantages of pressure sintering furnace
High production efficiency, less oxidation and decarbonization, saving material and forging die cost. Because the principle of medium frequency induction heating is electromagnetic induction, its heat is generated in the workpiece itself, ordinary workers can carry out the continuous work of forging task ten minutes after working in the sintering furnace, and there is no need for professional workers to burn and seal the furnace in advance. There is no need to worry about the waste of billet heated by coal furnace due to power failure or equipment failure. Compared with coal-fired furnace, this heating method can save at least 20-50kg steel raw materials per ton of forgings, and the material utilization rate can reach 95%. Because the heating method is uniform and the temperature difference between the core and the surface is very small, the service life of the forging die is greatly increased, and the surface roughness of the forging is less than 50um.
Excellent working environment, improve the working environment and company image, no pollution, low energy consumption. Compared with the coal stove, the workers in the sintering stove will no longer be baked and smoked by the coal stove in the hot sun, and can meet the requirements of various indicators of the environmental protection department. At the same time, it can establish the external image of the company and the future development trend of the forging industry. Induction heating is the most energy-saving heating method in electric heating furnace. The power consumption of ton forging heated from room temperature to 1100 ? is less than 360 degrees.
The heating is uniform, the temperature difference between the core and the meter is very small, and the temperature control precision is high. The heat of induction heating is generated in the workpiece itself, so the heating is uniform and the temperature difference between the core and the surface is very small. The application of temperature control system can realize accurate control of temperature and improve product quality and qualified rate. The heating device of pressure sintering furnace has the advantages of small volume, light weight, high efficiency, excellent hot working quality and favorable environment. It is rapidly eliminating coal-fired furnace, gas furnace, oil furnace and ordinary resistance furnace, and is a new generation of metal heating equipment.
M42 High Cobalt Toughness High Speed Steel Vacuum Heat Treatment Process
Zero Flow Process In Vacuum Nitriding Furnace
vacuum furnace
Looking for a new 3d printer
Yesterday, 06:04 PM in 3D Printers (Hardware)
