01-12-2021, 04:09 PM #1
- Jan 2021
Replicator 2 stopped working, prints raft then moves diagonally
Hi all
I am very new with 3D printers, but my makerbot replicator 2 is no longer working.
It prints the groundraft successfully and then suddenly moves diagonally into a corner, squirting filament in drops on the groundplane.
You can see a video of the problem here: https://youtu.be/IDRFLYuQ4b4
I have updated and reflashed the firmware (currently at 7.6).
Loaded and unloaded the filament. Homed the axis and leveled the bed.
I have tested a print file that worked without a problem previously.
I have tested printing from USB compared to SD-card.
I still prints the raft perfectly, which is strange. So it can still do the things it needs, move along the designed path and extrude.
I have no idea what is going on and what to try next.
Does someone have any idea what to try next to try and fix it? Has anyone ever seen this kind of behaviour before?
01-13-2021, 07:03 AM #2
is it every model or just a specific file ?
Try using Flashprint to slice (select replicator pro as the printer).
It sounds like it a problem with a specific file rather than with the printer itself.
As you say if it prints the raft than it's working.
02-11-2021, 01:03 PM #3
- Jan 2021
It was every file and it turned out to be a corrupt SD card.
(strange because I though I had already excluded that)
Jasper
Today, 02:50 AM in Tips, Tricks and Tech Help
