Results 1 to 10 of 12
12-17-2020, 04:01 AM #1
- Dec 2020
- 6
How to configure Tronxy XY-2 PRO at Cura.
Hey, everyone!
I just got my first printer and it is working well with gcode files that came with it, but when I try to print something from Cura it just don't move or react.
Anyone could help me about what I'm doing wrong?
It shows in the screen as if it's printing, but as youc an see in one of the images, the printer didn't even moved from it's starting point.
WhatsApp Image 2020-12-17 at 06.58.56.jpg WhatsApp Image 2020-12-17 at 06.58.49.jpg
This is a GCode created at Cura I'm trying to print GCode FileLast edited by Leisses; 12-17-2020 at 04:15 AM.
12-17-2020, 08:00 AM #2
I am 3D Printing your 3DBenchy now.
You may have selected the wrong settings for Machine configuration.
https://www.youtube.com/watch?v=0EORGq6fpt8Last edited by Roberts_Clif; 12-17-2020 at 08:05 AM.
12-17-2020, 04:24 PM #3
- Dec 2020
- 6
First try I just selected the printer at Ultimate Cura 4.8 version and nothing happened. I uninstalled Cura and deleted all files and started doing the same thing and no result.
Is there something I need to do at my printer? Is it needed to change firmware or something like that? Because I am running out of options now. I had already watched the link you sent and nothing changed.
Is it possible I need to change the GCode Flavor? I set it as Marlin, but never changed anything at printer.
12-17-2020, 06:34 PM #4
The Video I post stated that you should select Marlin at 3:00 minutes into video, Post one of the G-Code Models that do work will look inside.
12-17-2020, 06:46 PM #5
- Dec 2020
- 6
I was thinking if I should change the firmware of printer to Marlin instead of Tronxy's.
Here is one of those that works on it:
Dinosaur
12-18-2020, 06:47 AM #6
Quick look inside Dinosaur.gcode reveals :Flavor:Marlin
Marlin 1234.jpgLast edited by Roberts_Clif; 12-18-2020 at 06:59 AM. Reason: Can not see photo
12-19-2020, 03:42 AM #7
- Dec 2020
- 6
You're right. I saw that after posting. I tested other original files from Tronxy and not even all of them are printing. Only 3 out of 5 original files are working. It can't be something on the printer because it's working for some files, but it's really annoying that it doesn't work on any file I create =[
12-19-2020, 06:37 AM #8
Post your Profile form Preferences > Configure Cura... > Profile Select the Profile you sliced with and Post Export.
Post your Printer form Preferences > Configure Cura... > Printers > Machine Settings Screen Capture window crop and post.
This should be enough to see what is happening in your slicer, an determine if we need to check the printer.
12-19-2020, 06:56 AM #9
- Dec 2020
- 6
Thx for all the help.
Here are the files:
GCode
Printer Settings
Profile
I sent a new Gcode because I've been trying different things to fix it, but none is working, so maybe my gcode from now is different from the first I sent.
12-19-2020, 07:38 AM #10
As your first layer start at full speed I would change add Top/Bottom Speed.
On most models I print with a print speed between 65-86% My Start speed varies between 32-56% depending on complexity of model.
I believe you would experience better prints starting out in this area.Last edited by Roberts_Clif; 12-19-2020 at 07:43 AM.
