Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: ATMEGA blew up
  1. #11
    Jun 2017
    Location
    Washington State, USA
    Attaching Cura 15.04.6 images one With and one without Support Images and the estimating Print time.
    Printed model took a little longer 1hour 32 minutes Without supports.
    Actually I printed it without supports.
    As you can see there is little flaws near the Holes on edge of the left side.
    I have two of these Used Hictop a 3DP11 12volt and a 3DP12 24volt .
    In fact there is another used Hictop on E-Bay too bad I do not need or have space for another 3D Printer.
  2. #12
    Staff Engineer
    Jul 2016
    Location
    South Florida, USA
    Add AutoWiz on Facebook
    Oh no. Well Roberts_Clif my print time is behind you, sir..
    The item printed out well. I might have been able to get a better surface on the print if I dropped the nozzle temp 5c but no worries. It looks nice..
    So I am embarassed at this point. Obviously. Hat's off to you and your printer tuning capabilities, buddy. I will now chase what you are doing and identify flaws to fix. And TY for pointing me off in that direction. Mine printed in 1:51 or 111 minutes whereas your printed in 1:38 or 98 minutes. Yours printed 13% faster than mine. So now I reprint..
  3. #13
    Jun 2017
    Location
    I truly believe that the print times are so close that we both won.
    Both of us have figured out how to print the very best in the fastest time.
    I wish I could get a faster print time and you probably also want a faster print time.
    I can print faster though the models start look not so well and the the layer are not well laminated.
    Have even upped the nozzle temp with the printer speed helped a little though still sacrificed the model quality and lamination even printing in a heated enclosure.
    I have never had any problems with my current controllers other than the two I killed the stepper motor drivers IC chips on.
    Did we loose you EmperorShaohao this was your thread and we still want to help you just got side tracked.
