Thread: 3D Cad Software
  1. #1
    3D Cad Software
    Could anyone recommend a decent 3D CAD Software that is free and similar to SolidWorks or Inventor?
  2. #2
    Jun 2017
    Location
    Washington State, USA
  3. #3
    Onshape is free but your models are open to any other user of onshape.
    Just made a custom sanding adapter for my Rockwell multipurpose tool today. Worked out great!
  4. #4
    Student
    Nov 2020
    Location
    Oxford, UK
    Same boat. I used to use CorelDraw from early 1990s and found it great. Guess I got used to it. Also used IntelliCAD for dxf outputs by CorelDraw. And then HullForm to take the offsets from CD and develop the steel plating for a 22m vessel.CorelDraw was good in that it was very easy to adjust properties of an object. Almost intuitive. Select an object and its properties were simply displayed - dimensions, angles, thicknesses, fills etc. Just drew a box in Sketchup and no obvious object properties to simply adjust length and width??And prefer to download as I am often not connected to the www.
  5. #5
    You can try with FreeCAD, Fusion 360, and Meshmixer.
Tags for this Thread
